[Geoserver-users] Upload spatialite to GeoServer using REST API
I read about the supporting of uploading spatialite file to GeoServer at
http://docs.geoserver.org/stable/en/user/rest/api/datastores.html#workspaces-ws-datastores-ds-file-url-external-extension
And would like to know if I have to install an extension in order to use it?
as when using this command:
curl -u admin:geoserver -v -XPUT -H "Content-type: spatialite" --data-binary
@r2.sqlite
http://localhost:8080/geoserver/rest/workspaces/acme/datastores/s/file.spatialite
I got error: Datastore format unavailable:
org.geotools.data.spatialite.SpatiaLiteDataStoreFactory* Closing connection
0
I test with GeoServer 2.3.0 and 2.3.2, no extra extension installed
Thanks in advanced!
Regards.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-spatialite-to-GeoServer-using-REST-API-tp5062528.html
See this document - it includes a section on installing it.
http://docs.geoserver.org/stable/en/user/community/spatialite/index.html
Jonathan
On 27 June 2013 11:21, Hue <hdang99@anonymised.com4…> wrote:
curl -u admin:geoserver -v -XPUT -H “Content-type: spatialite” --data-binary
@r2.sqlite
0
Thanks in advanced!
Regards.
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Thanks Jonathan.
I installed the plugin geoserver-2.4-SNAPSHOT-spatialite-plugin.zip,
spatialite-libs-win-x86.zip
GeoServer 2.3.0
Use the same command:
@r2.sqlite
I received this:
* Adding handle: conn: 0xb8ac78
* Adding handle: send: 0
* Adding handle: recv: 0
* Curl_addHandleToPipeline: length: 1
* - Conn 0 (0xb8ac78) send_pipe: 1, recv_pipe: 0
* About to connect() to localhost port 8080 (#0)
* Trying 127.0.0.1...
* Connected to localhost (127.0.0.1) port 8080 (#0)
* Server auth using Basic with user 'admin'
PUT /geoserver/rest/workspaces/acme/datastores/s/file.spatialite HTTP/1.1
Authorization: Basic YWRtaW46Z2Vvc2VydmVy
User-Agent: curl/7.31.0
Host: localhost:8080
Accept: */*
Content-Length: 3970048
Expect: 100-continue
< HTTP/1.1 100 Continue
< HTTP/1.1 202 Accepted
< Date: Mon, 01 Jul 2013 07:56:02 GMT
* Server Noelios-Restlet-Engine/1.0..8 is not blacklisted
< Server: Noelios-Restlet-Engine/1.0..8
< Transfer-Encoding: chunked
* Connection #0 to host localhost left intact
GS log:
2013-07-01 INFO [catalog.rest] - PUT file, mimetype: spatialite
2013-07-01 INFO [catalog.rest] - Auto-configuring datastore: s
Spatial datastore s is created in GeoServer with workspace name, datastore
name. Other fields are empty.
No layer is created.
Have anyone succeeded with the command to create a layer in GS?
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-spatialite-to-GeoServer-using-REST-API-tp5062528p5063188.html
On Mon, Jul 1, 2013 at 10:08 AM, Hue <hdang99@anonymised.com> wrote:
Thanks Jonathan.
GeoServer 2.3.0
--data-binary
@r2.sqlite
I believe you're affected by the same problem as the H2 upload case
discussed
a few days ago:
https://jira.codehaus.org/browse/GEOS-5869
Long story short, the upload functionality was designed with shapefiles in
mind
and does not work with embedded spatial dbs, although I believe fixing it
should not be too hard.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea, thank you for your response.
Cheers.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-spatialite-to-GeoServer-using-REST-API-tp5062528p5063465.html
