[Geoserver-users] URL External Checks configuration
Hello there,
Is it possible to configure (at least enable/disable) the URL external checks with a REST API ? Or is it only possible through UI or configuration files?
Regards
Alexandre Gacon
I believe most of the security settings are managed as files that are scanned for changes; and thus can be managed directly on disk by a system administrator; or remotely via the “resource” REST API - which is intended to manage configuration files.
I do not think there is a new REST API endpoint for this functionality.
Jody Garnett
Alexandre Gacon
Thanks Jody for the reply. It is the strategy I have in mind but I have a few things to check out.
Correct me if I am wrong but I will have to ask GeoServer to reload the configuration after creating the resource with the REST API?
Regards
Alexandre
Jody Garnett
Alexandre Gacon
Alexandre Gacon
Check the docs, many of the security files are scanned, no rest so I reload required.
Jody Garnett
Jody Garnett
Alexandre Gacon
Alexandre Gacon
