[Geoserver-users] Use Geoserver REST to update layer name and title
I used the following command to publish an ImagePyramid layer:
curl -u $user:$password -XPUT -H "Content-type: text/plain" -d \
         'file:'$pyramidDir'' \
http://$host:$port/geoserver/rest/workspaces/$workspace/coveragestores/$datasetName/external.imagepyramid`
where:
$pyramidDir - /archive/maps/imagery/NAIP/Virginia-Beach/pyramid - This is
where the image pyramid was created using gdal_retile.py
$datasetName - Virginia-Beach
The layer was created successfully. However, the name and the title are
"pyramid". I would like it to be "Virginia-Beach" but don't know how to get
it to work. Not sure if I can specify the name and title when the layer is
created or update them afterward. Either way is ok with me. Any help on
this is greatly appreciated.
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/Use-Geoserver-REST-to-update-layer-name-and-title-tp5147983.html
I am able to update the layer's name and title using the following:
curl -u admin:geoserver -XPUT -H 'Content-type: application/xml' -d
'<coverage><title>Virginia Beach</title></coverage>'
http://localhost:8081/geoserver/rest/workspaces/vri/coveragestores/Virginia-Beach/coverages/pyramid.xml
My next question is how to I modify the converage parameters such as:
AllowMultiThreading
InputTransparentColor
etc.
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/Use-Geoserver-REST-to-update-layer-name-and-title-tp5147983p5148183.html
