[Geoserver-users] use j_spring_security_logout
Hi people i have no idea how does i use "j_spring_security_logout" to log out and what are the parameters to acomplish that, am using php, and i need some routine to do that, and my geoserver -s version is 2.1.4, please help, thanks
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
Hi, I’ve shared some PHP functions some time ago.
http://osgeo-org.1560.n6.nabble.com/Authenticate-in-Geoserver-from-PHP-application-td5009457.html
They were used with an older version of geoserver, but if you change the URL to j_spring_security_check or j_spring_security_logout… they should work.
Also, I’ve not used CURL at that time, but you should!!
Hope this can help!
Rodrigo C. Antonialli
Rio Claro - SP - Brasil
LinkedIn: http://www.linkedin.com/in/rcaprofile
Contato: (19) 8136-2347
rcantonialli@anonymised.com
Skype: rc_antonialli
On Tue, Mar 12, 2013 at 5:50 PM, <islanis@anonymised.com> wrote:
Hi people i have no idea how does i use “j_spring_security_logout” to
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
Geoserver-users mailing list
