[Geoserver-users] Use of MultiplyCoverages in a SLD
Hey,
I'm trying to implement a rendering trasformation by using the
gs:MultiplyCoverages function in a SLD. How can I define the coverageA and B
sources? My code is:
<Transformation>
  <ogc:Function name="gs:MultiplyCoverages">
    <ogc:Function name="parameter">
      <ogc:Literal>coverageA</ogc:Literal>
    </ogc:Function>
      <ogc:Literal>coverageB</ogc:Literal>
    </ogc:Function>
  </ogc:Function>
</Transformation>
The error I get is:
Could not convert the value {coverageA=myworkspace:myhillshade} into the
expected type class org.geotools.coverage.grid.GridCoverage2D for parameter
coverageA
Is there any documentation on how to implement this function?
Thank you so much!
Bye
Paolo
View this message in context: http://osgeo-org.1560.n6.nabble.com/Use-of-MultiplyCoverages-in-a-SLD-tp5025990.html
On Mon, Jan 7, 2013 at 4:55 PM, Paolo Pasquali <paolo.pasquali@anonymised.com…> wrote:
There is no way to support the function you want right now, a rendering transformation
can only work against the data coming from the layer you’re transforming, you
cannot do that with two layers.
That said, it is possible to think about adding new code, new features to the
transformation functionality allowing it to work against two layers at the same time…
but it’s going to take time, it’s not a quick hack, but the work of several days,
so it needs funding.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
