Regarding the discussion that we had on using XSLTs on WFS I just
realized that deegree is actually doing this.
In deegree you configure your FeatureTypes directly on the GML app
schema that you want it to use. An additionally you can make use of
XSLTs for tunings that are used after deegree has finished processing
the XML schema. I suppose it is a way to provide more flexibility.
Supporting all posibilities that an XML schema provides you can be
quite hard so tuning an XML message at the end with an XSLT can do the
trick.
Javier.
