[Geoserver-users] Use REST API to create style described in CSS
I would like to know if it’s possible to use the REST API to create or update layer style described in CSS, which will be much more easier to generate than SLD.
Thank you
Alexandre Gacon
It’s not possible. You can however run the CSS translator outside of GeoServer (see my comments in this thread http://thread.gmane.org/gmane.comp.gis.geoserver.user/35504 ) and then use the resulting SLD with the REST API.
On Tue, Feb 11, 2014 at 6:09 AM, Alexandre Gacon <alexandre.gacon@anonymised.com> wrote:
Thank you
Alexandre Gacon
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
David Winslow
Boundless - http://boundlessgeo.com/
