Hi. I have lot of cache files in TMS cache format. Is there any way that I can use them as a source (store?) in geoserver with geowebcache?
On Sat, Jun 25, 2016 at 11:01 AM, omid omidan <o.omidan@anonymised.com> wrote:
Hi Omid,
it's not possible, but I believe it should not be too hard to write a
GeoWebCache TileLayer subclass that works off
a TMS (either local or remote, it could be done either way by using a URL
template style, in a similar way
to what OpenLayers and Leaflet already do).
This would allow to add TMS layers by editing geowebcache.xml, adding a UI
on top of it is also possible
but it's certainly going to be more work (we don't have a precedent of a
pure tile source, disconnected
from GeoServer own layers).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
