On Fri, May 22, 2015 at 11:35 AM, Christian Mueller <
christian.mueller@anonymised.com> wrote:
Hi Andrea
Every authentication mechanism is affected.
In that case I guess applying the quick fix is better than nothing.
Investing some time would be better of course, but let's not
have best killing better.
The code snippet in the issue not a fix, this is a hack and there is no
guarantee that this hack is working for all authentication protocols.
Technical solution:
Each authentication mechanism is based on an GeoServerSecurityProvider
object. My idea is to have a reference from the authentication object to
the provider. The provider should have a method "extractPrincipal"
returning a string. This not easy since we use third party libraries from
Spring and CAS.
About privacy protection:
Many countries/enterprises/institutions do not allow grabbing statistical
data for specific users. For my biggest customer I solved the problem by
storing MD5 checksums of the username into PIWIK. As a consequence we need
a method extractPrincipalAsMD5 (or another algorithm) which gives the
possibility to collect and analyze anonymous statistical data.
Hum... interesting, however, we are not the law, also, and in most scenarios
were we used monitoring in audit mode, the clear username 99% of the reason
why monitoring is used (to track who did what and when).
Instead we should inform that collecting the user names might incur in
policy or legal issues, and provide a way to encode it if necessary.
The checksum of the user name should be the default and there is a need to
integrate this concept into the monitoring extension (including the GUI).
Not by default, breaks backwards compatibility
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
