[Geoserver-users] Using both ColorMap and ContrastEnhancement in SLD?
Hi! I’ve got a question about using the RasterSymbolizer in and SLD. Is it possible to use both a ColorMap as well as the ContrastEnhancement feature at the same time? When I try to combine both, I get a validation error (and no images are generated via WMS requests) but I’m unsure exactly what the error means.
The underlying dataset in this case is a GeoTIFF where pixels contain temperature values.
The SLD that is working is:
<sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld” xmlns:sld=“http://www.opengis.net/sld” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:gml=“http://www.opengis.net/gml” version=“1.0.0”>
sld:NamedLayer
sld:Namencep_air_temperature_current_month_forecast_average</sld:Name>
sld:UserStyle
sld:Titlencep_air_temperature_current_month_forecast_average</sld:Title>
sld:FeatureTypeStyle
sld:Namename</sld:Name>
sld:Rule
sld:RasterSymbolizer
(… snipping many other values …)
</sld:RasterSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
What I’d like to try out is:
sld:NamedLayer
sld:UserStyle
sld:Rule
(… snip many other entries…)
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
When I try this, I get this validation error:
line 15: cvc-complex-type.2.4.a: Invalid content was found starting with element ‘ColorMap’. One of ‘{“http://www.opengis.net/sld”:ShadedRelief, “http://www.opengis.net/sld”:ImageOutline}’ is expected.
I can understand that an explicit color map along with a histogram may not make sense, but wanted to give it a try and wasn’t quite sure how to interpret this error message.
Relevant version information:
Geoserver Version - 2.7-SNAPSHOT
Git Revision - 98c8cdc76eaca4d97043edbe2590927dd12fc4a8
Build Date - 04-Oct-2015 13:52
GeoTools Version - 13-SNAPSHOT (rev c93ba46e2f17bc598279d80722b66d14f7877fe7)
GeoWebCache Version - 1.7-SNAPSHOT (rev 00c39227c0fb6d9a7d0b347ae4875dad457de69b/00c39227c0fb6d9a7d0b347ae4875dad457de69b)
Bruce Crevensten
Senior Software Engineer
(SNAP) Scenarios Network for Alaska & Arctic Planning
www.snap.uaf.edu
Thinking...
it might work if you use the sld:ChannelSelection.
Something like:
<sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld&quot;
xmlns:sld="http://www.opengis.net/sld&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
xmlns:gml="http://www.opengis.net/gml&quot; version="1.0.0">
  <sld:NamedLayer>
    <sld:Name>ncep_air_temperature_current_month_forecast_average</sld:Name>
    <sld:UserStyle>
      <sld:Title>ncep_air_temperature_current_month_forecast_average</sld:Title>
      <sld:FeatureTypeStyle>
        <sld:Name>name</sld:Name>
        <sld:Rule>
          <sld:RasterSymbolizer>
            <ChannelSelection>
              <GrayChannel>
                <SourceChannelName>1</SourceChannelName>
                  <ContrastEnhancement>
                     <Histogram/>
                  </ContrastEnhancement>
               </GrayChannel>
            </ChannelSelection>
            <ColorMap>
              <ColorMapEntry quantity='-50' label='-50 ºC' color='#3B4CC0' />
              <ColorMapEntry quantity="-30" label="-30 ºC" color="#3B4CC0" />
              <ColorMapEntry quantity="28.125" label="28.125 ºC"
color="#C0282F" />
              <ColorMapEntry quantity="30" label="30 ºC" color="#B4426" />
            </ColorMap>
        </sld:Rule>
    </sld:UserStyle>
  </sld:NamedLayer>
Mind you, I have not tried it.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Jan 21, 2016 at 8:55 PM, Bruce Crevensten
<becrevensten@anonymised.com> wrote:
Hi! I've got a question about using the RasterSymbolizer in and SLD. Is it
no images are generated via WMS requests) but I'm unsure exactly what the
error means.
temperature values.
  <sld:NamedLayer>
    <sld:UserStyle>
        <sld:Rule>
            <ColorMap>
               (... snipping many other values ...)
color="#C0282F" />
            </ColorMap>
        </sld:Rule>
    </sld:UserStyle>
  </sld:NamedLayer>
What I'd like to try out is:
  <sld:NamedLayer>
    <sld:UserStyle>
        <sld:Rule>
              <Histogram/>
            <ColorMap>
              (... snip many other entries...)
color="#C0282F" />
            </ColorMap>
        </sld:Rule>
    </sld:UserStyle>
  </sld:NamedLayer>
element 'ColorMap'. One of '{"http://www.opengis.net/sld&quot;:ShadedRelief,
"http://www.opengis.net/sld&quot;:ImageOutline\}' is expected.
make sense, but wanted to give it a try and wasn't quite sure how to
Bruce Crevensten
www.snap.uaf.edu
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
