Hi All,
I’m currently trying to put together an SLD style (for WMS use) that will crop a raster coverage layer to the borders of an administrative unit (chosen by id).
This question has been asked in various forms a lot of times before: 1, 2, 3, 4, 5, but never quite got a full working answer.
I have a raster layer/store, and a postgis multipolygon feature collection layer/store. I want to crop the raster by one of the multipolygon selected using a wms parameter.
Here’s what I’ve tried:
A style applied to the raster layer, with a static WKT shape.
This works, but doesn’t do what i’m looking for (shape not from postgis)
The WKT could be provided externally using “env” substitution, but my shapes are far too complex to do this in a HTTP request.
A style applied to the raster layer, which uses “gs:Query” to load the vector data and filter.
This doesn’t work as there doesn’t seems to be a way to specify the name of the layer/store from which to load a feature collection.
A style applied to the vector layer, with a cql_filter to select only a single multipolygon, which uses “gs:GetFullCoverage” to load the raster data
This almost works, it crashes at run time. Is it treating a mutipolygon as a polygon maybe?
org.postgresql.util.PSQLException: ERROR: parse error - invalid geometry Hint: “POLYGON ((-?” ← parse error at position 12 within geometry, at org.geotools.process.function.ProcessFunction.evaluate
I think there is probably a way to make this approach work, (gs:GetFullCoverage work with static WKT)
SLD 3
There is clearly demand of this functionality, so it would be good to get a working example of this into the official documentation (@ User Manual » Styling » SLD Extensions in GeoServer » Rendering Transformations).
Anyone have any idea how I can get this to work?
Rob
