Hi!
I use WWJ WMS to serve srtm30 and the Blue Marble 2004 data successfully.
Then I use DDS/BIL and ImageMosaic plugins in geoserver 2.5 to replace WMS.
I can receive data in WWJ. The Blue Marble data is fine, but srtm30 is
error. The Image that display in WWJ has many burrs. It liks the jagged
outline of the crags and scraggy cliff.
I works in Windows 8 X64. Thd WWJ version is worldwind-daily-933.1842. The
Geoserver is 2.5.
I have tried multiple method but failure.
Can you help me?
Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-geoserver-to-serve-elevation-data-in-WorldWind-tp5103498.html
Ciao,
the DDS community plugin has not received any attention since ages, hence I am not sure it works properly.
Being a community modules it means it is not maintained as an official extension hence you should not expect it to work properly.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Feb 13, 2014 at 6:08 AM, redtramp <redtramp@anonymised.com> wrote:
Hi!
Geoserver is 2.5.
Can you help me?
Thanks!
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Thanks for you replay.
I has solved this problem today.
What i do is change "byteOrder" in "ElevationModelAsBil16.xml" from
"LitterEndian" to "BigEndian".
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-geoserver-to-serve-elevation-data-in-WorldWind-tp5103498p5104135.html
Ciao,
can you be more specific?
Others might find this helpful…
Simone Giannecchini
@simogeo
Founder/Director
What i do is change “byteOrder” in “ElevationModelAsBil16.xml” from
“LitterEndian” to “BigEndian”.
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
