Hi Derek,
a SVG normally declares its bounds in the header, often using a viewBox attribute:
http://jonibologna.com/svg-viewbox-and-viewport/
May it be that your SVG have a viewbox selecting just a part of it?
On Tue, Sep 20, 2016 at 9:27 AM, Derek Watling <derek@anonymised.com> wrote:
I am running GeoServer 2.9.0 and using CSS styling. I set up my style to
render a mark which sizes and positions depending on the zoom level.
Originally I used a PNG for the mark, and once I was happy with the result I
created a SVG using Inkscape. When I replace the PNG with the SVG it does
not appear to resize the image according to mark-size, but rather uses the
top left corner of the SVG. The SVG is fairly big relative to final size it
is rendered.
Any help / considerations on using SVG would be appreciated.
As rendered using PNG:
<http://osgeo-org.1560.x6.nabble.com/file/n5286825/png-mark.png>
As rendered unsing SVG:
<http://osgeo-org.1560.x6.nabble.com/file/n5286825/svg-mark.png>
SVG viewed in Firefox:
<http://osgeo-org.1560.x6.nabble.com/file/n5286825/svg-firefox.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-SVG-image-as-Mark-not-resizing-tp5286825.html
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
