I'm testing 1.7 and I have the strange feeling that description.ftl, title.ftl files vanish while using Geoserver ... has somebody had the same experience ?
Laurent
Laurent
Hi Laurent,
Yes, others have seen the same thing happen, but not been able to reproduce it. Are you able to reproduce the problem? Or is it something that just happened randomly?
On 1.7.x, the feautreType directories are backed up. So you should be able to recover your files from the .bak counterparts.
-Justin
laurent pierrre wrote:
Laurent
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Laurent,
Apologies, i mis understood the problem. Yes this is an issue which occurs during saving. I have opened an issue report for this.
http://jira.codehaus.org/browse/GEOS-2368
It will be fixed in 1.7.1. For the time being the files should be located in the .bak directory corresponding to the feature type. They are not totally lost so you can copy them back over every time you save.
-Justin
Justin Deoliveira wrote:
Hi Laurent,
-Justin
Laurent
Justin Deoliveira
Hi Justin,
Yes it happened randomly and it took time for me to figure out what happened ;). When you say 1.7.x you mean the future versions ?
Laurent
2008/11/10 Justin Deoliveira <jdeolive@anonymised.com>
Hi Laurent,
-Justin
I’m testing 1.7 and I have the strange feeling that description.ftl, title.ftl files vanish while using Geoserver … has somebody had the same experience ?
Laurent
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
https://lists.sourceforge.net/lists/listinfo/geoserver-users–
Justin Deoliveira
les Pierre ha scritto:
Hi Justin,
No, he also means 1.7.0. When you save the current feature type directory is stored as featuretypeName.bak.
Unfortunately, I guess that if you save twice in a row without checking,
the old backup gets wiped out to make place for the new one, and
your templates are gone for good.
Andrea Aime
