[Geoserver-users] Variable substitution not working if multiple layers are provided in WMS call
Hello,
I use cql expressions to make my color map entries dynamic as described
here:
http://docs.geoserver.org/2.8.x/en/user/styling/sld-reference/rastersymbolizer.html#cql-expressions
It works basically, but as soon as I add an additional layer in my WMS call
(&layers=layer1,layer_raster) the parameters I pass in the URL
(&env=low:10;medium:100;...) are just ignored and the default values I
defined with the cql expression are applied.
Does anyone know about this issue? I am using GeoServer 2.8.0.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Variable-substitution-not-working-if-multiple-layers-are-provided-in-WMS-call-tp5271011.html
Hi Paul,
I reproduced the bug, and the fix should be easy. Could you open a JIRA in the meantime?
Mauro Bartolomeoli
2016-06-10 10:41 GMT+02:00 hanshupe <paul.schneeweiss@anonymised.com>:
Hello,
here:
(&env=low:10;medium:100;…) are just ignored and the default values I
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Thanks Mauro, would be great.
I opened the JIRA here: https://osgeo-org.atlassian.net/browse/GEOS-7579
View this message in context: http://osgeo-org.1560.x6.nabble.com/Variable-substitution-not-working-if-multiple-layers-are-provided-in-WMS-call-tp5271011p5271184.html
Does anybody know when a fix on this issue will be available? Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Variable-substitution-not-working-if-multiple-layers-are-provided-in-WMS-call-tp5271011p5277454.html
Did you read the user list posting guidelines?
http://geoserver.org/comm/userlist-guidelines.html
Check the last section, “If it turns out it’s a bug”
On Wed, Jul 20, 2016 at 10:33 PM, hanshupe <paul.schneeweiss@anonymised.com> wrote:
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports.http://sdm.link/zohodev2dev
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ah, btw, it turned out the fix is not trivial, the change Mauro was considering is causing other test failures.
I have a solution in mind, but it’s not a half an hour one.
On Thu, Jul 21, 2016 at 8:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
