For those who are reading this mails from the archives sometimes in the future, the same question was also asked in
http://gis.stackexchange.com/questions/197867/variable-substitution-not-working-if-multiple-layers-are-provided-in-wms-call
It is possible that it gets an answer in gis.stackexchange and no reaction on the mailing lists, or vice versa.
-Jukka Rahkonen-
hanshupe wrote:
Hello,
I use cql expressions to make my color map entries dynamic as described
here:
http://docs.geoserver.org/2.8.x/en/user/styling/sld-reference/rastersymbolizer.html#cql-expressions
It works basically, but as soon as I add an additional layer in my WMS call
(&layers=layer1,layer_raster) the parameters I pass in the URL
(&env=low:10;medium:100;...) are just ignored and the default values I defined with the cql expression are applied.
Does anyone know about this issue? I am using GeoServer 2.8.0.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Variable-substitution-not-working-if-multiple-layers-are-provided-in-WMS-call-tp5271011.html
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic patterns at an interface-level. Reveals which users, apps, and protocols are consuming the most bandwidth. Provides multi-vendor support for NetFlow, J-Flow, sFlow and other flows. Make informed decisions using capacity planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
