Thanks for your comments and help this far.
One further thing, on top of using zoom levels, im also trying to
implement rule based vector styles, and when I validate the sld its
just throws up errors. Can I do the two things at the same time?
I have included below my (poor) sld code:
Thanks again!
Chris
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version="1.0.0"
xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
<NamedLayer>
<Name>Default Point</Name>
<UserStyle>
<Title>Default point</Title>
<Abstract>A sample style that just prints out a 6px wide red
square</Abstract>
<FeatureTypeStyle>
<MinScaleDenominator>100000000</MinScaleDenominator>
<MaxScaleDenominator>200000000</MaxScaleDenominator>
<Rule>
<Name>Lowest Exposure</Name>
<Title>4</Title>
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>ThematicKey</ogc:PropertyName>
<ogc:Literal>1</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#58FAF4</CssParameter>
</Fill>
<Stroke></Stroke>
</PolygonSymbolizer>
</Rule>
<Rule>
<Name>Upper Middle Exposure</Name>
<Title>3</Title>
<ogc:Filter>
<ogc:Literal>2</ogc:Literal>
</ogc:Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#2EFE2E</CssParameter>
</Fill>
<Stroke></Stroke>
</Rule>
<Rule>
<Name>Lower Middle Exposure</Name>
<Title>2</Title>
<ogc:Filter>
<ogc:Literal>3</ogc:Literal>
</ogc:Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#FF8000</CssParameter>
</Fill>
<Stroke></Stroke>
</Rule>
<Rule>
<Name>Highest Exposure</Name>
<Title>1</Title>
<ogc:Filter>
<ogc:Literal>4</ogc:Literal>
</ogc:Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#DF0101</CssParameter>
</Fill>
<Stroke></Stroke>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
-----Original Message-----
From: christian.mueller@anonymised.com [mailto:christian.mueller@anonymised.com]
Sent: 13 October 2010 02:36
To: Jones, Christopher
Cc: Geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Vector Layers - Zoom Pyramid
The counterpart of pyramids for raster are generalizations for vector
data, reducing the number of vertices for a geometry.
Look here
http://docs.geoserver.org/stable/en/user/data/featurepregen.html
and
http://docs.geoserver.org/stable/en/user/tutorials/feature-pregeneralize
d/feature-pregeneralized_tutorial.html
The standard configuration is an XML document, but I personally use a
plugin fetching config data from the database.
In case of further questions, please ask.
Christian
Quoting "Jones, Christopher" <Christopher.Jones@anonymised.com>:
Probably a stupid question but I cant seem to find any answers to
this.
I have three vector layers State, County and Zip, and would like to
display them at different zoom levels. Beyond the Image Pyramid
plugin
which is for raster data, is this possible?
Thanks in advance
Chris
IMPORTANT - This email and the information that it contains may be
confidential, legally privileged and protected by law. Access by the
intended recipient only is authorised. Any liability (in negligence
or otherwise) arising from any third party acting, or refraining
from acting, on any information contained in this email is hereby
excluded. If you are not the intended recipient, please notify
AmlinCommunications@anonymised.com immediately then delete it and do
not disclose the contents to any other person, use it for any
purpose or store or copy the information in any medium.
Copyright in this email and attachments created by us belong to
Amlin plc and/or one or more of its subsidiaries (Amlin Group). The
author also asserts the right to be identified as such and object to
any misuse.
The Amlin Group prohibits and takes steps to prevent its email
systems from being used to view, store or transmit offensive,
obscene or discriminatory material. If this message contains
inappropriate material please report it immediately to
The Amlin Group records, monitors and may inspect messages that use
its telecoms systems in order to protect its information, interests
and reputation. Any message sent by you to or within the Amlin Group
may therefore be viewed and may be acted upon.
Of the companies within the Amlin Group, Amlin Underwriting Limited,
Amlin Underwriting Services Limited, Amlin UK Limited and Amlin
Plus Limited are authorised and regulated by the Financial Services
Authority.
This email has been sent by a member of staff of one or more of the
following Amlin Group companies:
Amlin plc. Registered in England and Wales no. 2854310
Amlin Underwriting Limited. Registered in England and Wales no.
2323018
Amlin Underwriting Services Limited. Registered in England and Wales
no. 422615
Amlin UK Limited. Registered in England and Wales no. 2739220
Amlin Plus Limited. Registered in England and Wales no. 4729659
Registered Offices: St Helen's, 1 Undershaft, London EC3A 8ND, United
Kingdom
Amlin plc switchboard: 020 7746 1000
Web Site: http://www.amlin.com
This message was sent using IMP, the Internet Messaging Program.
IMPORTANT - This email and the information that it contains may be confidential, legally privileged and protected by law. Access by the intended recipient only is authorised. Any liability (in negligence or otherwise) arising from any third party acting, or refraining from acting, on any information contained in this email is hereby excluded. If you are not the intended recipient, please notify AmlinCommunications@anonymised.com immediately then delete it and do not disclose the contents to any other person, use it for any purpose or store or copy the information in any medium.
Copyright in this email and attachments created by us belong to Amlin plc and/or one or more of its subsidiaries (Amlin Group). The author also asserts the right to be identified as such and object to any misuse.
The Amlin Group prohibits and takes steps to prevent its email systems from being used to view, store or transmit offensive, obscene or discriminatory material. If this message contains inappropriate material please report it immediately to AmlinCommunications@anonymised.com
The Amlin Group records, monitors and may inspect messages that use its telecoms systems in order to protect its information, interests and reputation. Any message sent by you to or within the Amlin Group may therefore be viewed and may be acted upon.
Of the companies within the Amlin Group, Amlin Underwriting Limited, Amlin Underwriting Services Limited, Amlin UK Limited and Amlin Plus Limited are authorised and regulated by the Financial Services Authority.
This email has been sent by a member of staff of one or more of the following Amlin Group companies:
Amlin Underwriting Limited. Registered in England and Wales no. 2323018
Amlin Underwriting Services Limited. Registered in England and Wales no. 422615
Registered Offices: St Helen's, 1 Undershaft, London EC3A 8ND, United Kingdom
