[Geoserver-users] Vector rendering problem
I have Geoserver installed on Linux. Both of my examples below are reading the same postgres/postgis geometry dataset. Data is being served dynamically, no tile caching. Both examples are generated using equivalent WMS ‘GetMap’ requests. The first example is using GeoServer version 2.2. The second example is using version 2.7. How come the 2.7 version drops a lot of the polygons? For faster rendering?? This is a somewhat complex dataset, but not THAT complex (the whole thing renders pretty fast in version 2.2). Is there a setting/config that I can adjust to make 2.7 behave like 2.2?
Thanks!
Inline image 1
Don Brown
GIS Specialist
Cherokee Services Group, LLC (CSG)
Contractor to the U.S. Geological Survey
Fort Collins Science Center
2150 Centre Ave. Bldg. C
Fort Collins, CO 80526
(970) 226-9155
brownd@anonymised.com
On Fri, Apr 24, 2015 at 1:36 AM, Brown, Donald <brownd@anonymised.com> wrote:
WMS 'GetMap' requests. The first example is using GeoServer version 2.2.
behave like 2.2?
Yes, disable the postgis side data simplification, it's a new toggle in the
postgis store options.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
