HI David,
the GWC preview can show vector tiles, and it’s based on OpenLayers, so you can probably steal some idea there.
You can find it in the “tile layers” menu entry.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
HI David,
Hi David,
I haven’t tried, but believe it’s not possible, the vector tile output format does not seem to take
care of that parameter (by a quick check in the code).
When it was first donated, it did not even account for CQL_FILTER, we had to add it later…
Pull requests welcomed to add support for that parameter
Hi David,
HI David,
If the data is small enough, maybe? But mind, the OGC “Vector Tiles Pilot 2” had as one of its central
focuses, being able to run filters on the OGC API - Tiles. And specifically, for vector tiles.
So, not as odd as you might think, but a controversial topic for sure.
I wrote the engineering report for that, you’ll be able to read it soon, as it’s made publicly available (it’s not, yet).
I’m making a map displaying COVID-19 data for the US at state and county levels. I was able to get data to render slowly in mapbox using Geoservers mapbox vt plug in. I’m wondering if there is a better way to do it.
Right now I have daily data stored in a Postgresql database with geometry. What are the best practices for publishing data of that scale? Should I just load the JSON and add data to that through an API?
Hi David,
HI David,
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
