[Geoserver-users] Version & ADRG Formats
I have a couple of questions for you about GeoServer. First question is how the heck do I identify the version I’m running? Second question is I’m trying to load NIMA ADRG map files without any luck. Is that format supported? If so, what raster data source do I select?
Richard Irvin
IT Specialist
SPAWAR Systems Center (SSC) Pacific
619.553.4047
rick.irvin@anonymised.com
the heck do I identify the version I'm running? Second question is I'm
Richard Irvin
You probably need the GDAL extension
http://docs.geoserver.org/latest/en/user/data/raster/gdal.html
Format support described at
http://gdal.org/frmt_various.html#ADRG
If the plugin doesn't work directly you can use GDAL to convert the data
sources into something that does work well with Geoserver.
Alex
