[Geoserver-users] Very basic question - Geowebcache <> Geoserver
You can use geowebcache in addition to integrated layers.
Edit file
/webapps/geoserver/WEB-INF/web.xml
Add section like
GEOWEBCACHE_CACHE_DIR
/users/geoserver/data/gwc
Now write geowebcache.xml, save it into the GEOWEBCACHE_CACHE_DIR and restart the server. Work at least for me. After doing this the integrated GWC has the layers from Geoserver plus layers defined in geowebcache.xml.
-Jukka Rahkonen-
Stefan wrote:
Thanks for your quick reply, yes I knew that was available
??Doesn’t the integrated Geowebcache show the tiled layers by retrieving the GeoServer GetCapabilities - So there isn’t a specific geowebcache.xml I can look at
I need to build as separate servers to investigate some service configuration & scaling options that we are thinking about
So I need to figure out what should be in my geowebcache.xml
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 08 April 2014 20:00
To: Stefan
Cc: GeoServer Mailing List List
Subject: Re: [Geoserver-users] Very basic question - Geowebcache <> Geoserver
On Tue, Apr 8, 2014 at 8:53 PM, Stefan <smaric@anonymised.com…4505…> wrote:
I have got my GeoServer configured with some vector data sets in several postGIS DBs
I have configured GeoServer layers & can see these via the view Layers page
I can’t seem to figure out how to configure Geowebcache to reference the Layers in Geoserver
Note I have Geowebcache and Geoserver deployed to separate WebApp servers
Hope someone can share a geowebcache.xml and the equivalent GeoServer Layer configurations
GeoServer ships with GeoWebCache integrated into it, no need to deploy it as a separate applications.
Unless you changed the default, all your layers are also already published as tile caches too
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
