[Geoserver-users] very thin 1 pixel width
Thanks Andrea! I like it, it really gives you more control for the stroke widths.
regards
Stefan
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet am: Freitag, 23. Januar 2009 19:33
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: AW: Re: [Geoserver-users] very thin 1 pixel width
Ziegler Stefan ha scritto:
From my point of view (as a happy user who doesn’t like
the thin lines
;)) I would appreciate a “web.xml”-solution as with the new
labeller.
I’ve just commited the changes for
http://jira.codehaus.org/browse/GEOS-2228
So starting from tomorrow you can grab a nightly build and test out
a build that does not do super-thin lines.
All you have to do is to add the following to your web.xml:
OPTIMIZE_LINE_WIDTH false
(the meaning is that the code turned every line width less than 1.5
to 0 to get into a fast path in the java2d rendering code, and
if you disable it, you give up the faster path for better line
width control).
I’m actually not super happy with that setting name but
could not come up with a better one so… suggestions
welcomed.
PS: the nightly build you can grab here:
http://gridlock.openplans.org/geoserver/1.7.x/
Andrea Aime
OpenGeo - http://opengeo.org
