Hello,
Absolutely new to Geo-Server and I am in here to evaluate how good its performance and stability when compared to other mapping engines available. In this process I am trying to load large Oracle data (around 750K polygon records) via a layer/Feature. The connection to Oracle 11G is fine and the OpenLayers viewer even shows the attributes at the bottom when clicked on the map. But I can’t see any polygons on the viewer?! I have populated the Oracle geometry object with the SRS of 28355 and GeoServer admin picks these values correctly and after around 10-15 mins. it generates the ‘Bounding Box” correctly.
I am struck here and not sure how to proceed further. Any suggestions to move forward would be highly appreciated. FYI, the spatial indexes also exist in the database.
Best regards,
Praveen
Hi Praveen,
If wfs requests are resulting fine the wms requests should too.
The featureType SLD you’re applying is a default one that comes with
Geoserver or you built a new one? If so, try to apply a default one in the
wms request, maybe the default_polygon.sld (polygon fill set to #AAAAAA and
stroke to black with 1 pixel width) or capitals (you’ll see circles instead
of the polygon geometries).
Hope this helps,
Pedro Mendes
Praveen-22 wrote:
Hello,
when clicked on the map. But I can't see any polygons on the viewer?! I
it generates the 'Bounding Box" correctly.
Best regards,
Praveen
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Viewing-Oracle-data-in-GeoServer-OpenLayers-tp21489559p21496353.html
Thanks for your response, Pedro.
I am using the “polygon” SLD which came along with Geoserver. No changes done. I can’t see a “default_polygon” as part off the “Additional Styles” listbox?
The WMS URL request is:
http://ossup1:8080/geoserver/wms?bbox=261094.19701362215,5785552.355577179,332702.2716097879,5845206.345511841&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=CWW:CWW_PARCEL&width=800&height=625&srs=EPSG:28355
Anything else can I try?!
Thanks and regards,
Praveen
Sent: Friday, 16 January 2009 9:18 PM
To: Praveen Rajendra Babu
Subject: RE: [Geoserver-users] Viewing Oracle data in GeoServer-OpenLayers
Hi Praveen,
The featureType SLD you’re applying is a default one that comes with Geoserver or you built a new one? If so, try to apply a default one in the wms request, maybe the default_polygon.sld (polygon fill set to #AAAAAA and stroke to black with 1 pixel width) or capitals (you’ll see circles instead of the polygon geometries).
Hope this helps,
Pedro Mendes
De: Praveen Rajendra Babu [mailto:prbabu@anonymised.com]
Enviada: quinta-feira, 15 de Janeiro de 2009 23:38
Para: geoserver-users@lists.sourceforge.net
Assunto: [Geoserver-users] Viewing Oracle data in GeoServer-OpenLayers
Hello,
Best regards,
Praveen
