[Geoserver-users] W3DS geoserver3D does not run under windows 7 64 bit
Hello 3d people,
the W3DS community version of geoserver (geoserver3D.war) does not run under Windows 7 64 bit. I have installed Apache Tomcat / 8.0.12. Geoserver3D is listed in the Web Application Manager of Tomcat. But when I try to start geoserver3D I get the following message: "FAIL - Application at context path / geoserver3D could not be started"
Under Win XP geoserver3D works fine on Apache Tomcat / 8.0.12.
Does anyone have an idea?
Best Regards
Frank
What is geoserver3D.war ? If it is some pre-build of Geoserver with the
community W3DS module enable it is probably outdated.
A colleague build the current (master) version of Geoserver with W3DS
community module enable. We try it using:
- Windows 7 64 Bit
- Apache Tomcat 8.0.12
- JDK\JRE 7_60 64 Bit
And all worked fine.
I upload the Geoserver.war we build to my dropbox if you want to give a
try:
https://dl.dropboxusercontent.com/u/31843558/geoserver_windows7_64bit_test.war
Best regards,
Nuno Oliveira
Le mercredi 24 septembre 2014 à 10:25 +0100, Frank Henze a écrit :
Hello 3d people,
Best Regards
Frank
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
where can I find the latest version of W3DS community module?
Frank
Am 24.09.2014 um 13:01 schrieb Nuno Oliveira:
- Windows 7 64 Bit
try:
Best regards,
Nuno Oliveira
Hello 3d people,
Best Regards
Frank
Le mercredi 24 septembre 2014 à 16:08 +0100, Frank Henze a écrit :
W3DS is a community module so is not included by default in
geoserver.war. You need to build the module by your self.
You have two options:
* you build the geoserver.war using: mvn install -Pw3ds -DskipTests=true
* you only build the W3DS community module and deploy it with the
pre-build geoserver.war.
Geoserver source code is available on Github:
https://github.com/geoserver/geoserver
I know this is not very user friendly, but W3DS still a community
module ...
Frank
> Hi,
> - Windows 7 64 Bit
> try:
> Best regards,
> Nuno Oliveira
>> Hello 3d people,
>> Best Regards
>> Frank
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
https://github.com/geoserver/geoserver/tree/master/src/community/w3ds
Paulo
-----Mensagem Original----- From: Frank Henze
Sent: Wednesday, September 24, 2014 4:08 PM
To: Nuno Oliveira
Cc: PMachado ; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] W3DS geoserver3D does not run under windows 7 64 bit
Frank
- Windows 7 64 Bit
try:
Best regards,
Nuno Oliveira
Hello 3d people,
Best Regards
Frank
module ...
Frank
> Hi,
> - Windows 7 64 Bit
> try:
> Best regards,
> Nuno Oliveira
>> Hello 3d people,
>> Best Regards
>> Frank
