[Geoserver-users] W3DS geoserver3D does not run under windows 7 64 bit
Thanks Nuno,
geoserver36.war is the old prebuild version found on
http://3dwebgis.di.uminho.pt/sources/.
After some back and forth with 32 and 64 bit Java
geoserver_windows7_64bit_test.war seems to run. Thanks for the prompt
assistance!
Is there current work on the W3DS implementation? We want to use W3DS
for an archaeological 3D WebGIS together with X3DOM/WebGL.
Is it possible to integrate also X3D files as layers with the W3DS
version, analogous to the integration of shapefiles?
Thanks again
frank
Am 24.09.2014 um 13:01 schrieb Nuno Oliveira:
What is geoserver3D.war ? If it is some pre-build of Geoserver with the
community W3DS module enable it is probably outdated.
A colleague build the current (master) version of Geoserver with W3DS
community module enable. We try it using:
- Windows 7 64 Bit
- Apache Tomcat 8.0.12
- JDK\JRE 7_60 64 Bit
And all worked fine.
I upload the Geoserver.war we build to my dropbox if you want to give a
try:
https://dl.dropboxusercontent.com/u/31843558/geoserver_windows7_64bit_test.war
Best regards,
Nuno Oliveira
Le mercredi 24 septembre 2014 à 10:25 +0100, Frank Henze a écrit :
Hello 3d people,
the W3DS community version of geoserver (geoserver3D.war) does not run
under Windows 7 64 bit. I have installed Apache Tomcat / 8.0.12.
Geoserver3D is listed in the Web Application Manager of Tomcat. But when
I try to start geoserver3D I get the following message: "FAIL -
Application at context path / geoserver3D could not be started"
Under Win XP geoserver3D works fine on Apache Tomcat / 8.0.12.
Does anyone have an idea?
Best Regards
Frank
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Le mercredi 24 septembre 2014 à 15:58 +0100, Frank Henze a écrit :
Thanks Nuno,
This the first version of W3DS community module so it is very old :slight_smile:
assistance!
Welcome.
Recently the support to XML3D format have been added by the guys from
http://cyberlightning.com. They may take the lead of the module but I
don't really know the current development status ... someone else ?
We want to use W3DS
Currently you can't but seems to be a nice idea ... but at this time you
can reference you X3D as a model in the SLD
http://osgeo-org.1560.x6.nabble.com/W3DS-Inclusion-of-3D-Models-X3D-KML-td5051352.html
Thanks again
frank
> Hi,
> - Windows 7 64 Bit
> try:
> Best regards,
> Nuno Oliveira
>> Hello 3d people,
>> Best Regards
>> Frank
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Thanks Nuno,
assistance!
Welcome.
We want to use W3DS
Thanks again
frank
> Hi,
> - Windows 7 64 Bit
> try:
> Best regards,
> Nuno Oliveira
>> Hello 3d people,
>> Best Regards
>> Frank
