Dear All, Just trying to install geoserver on Fedora Core 4 running Tomcat 5.
I have other application running fine under Tomcat but when I try to
deploy the war using the Tomcat Web Application Manager I get:
FAIL - Encountered exception java.io.IOException:
java.net.MalformedURLException: Absolute URL required with null
context
Can anyone help?
Many thanks,
Dan
What version of Java and GeoServer are you running?
Sure it's Sun's java?
context
Can anyone help?
Many thanks,
Dan
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert advice straight from the developers
Yes, gcj is not sufficient.
For GeoServer 1.6.5 you need Sun JDK 1.4.2 , but newer versions will give you better performance.
Please look for Fedora 4 guides, here is one: http://www.mjmwired.net/resources/mjm-fedora-fc4.html . However, make sure you get the JDK, not the JRE.
-Arne
ps. please keep conversation on list.
Dan Lear wrote:
Hi I'm using the latest stable ver of geoserver (1.6.5)
Java -version says:
java version "1.4.2"
gij (GNU libgcj) version 4.0.0 20050519 (Red Hat 4.0.0-8)
I've got v. little java experience, so have I got to change the version
of java?
Thanks
Dan
-----Original Message-----
From: Arne Kepp [mailto:ak@anonymised.com] Sent: 29 September 2008 16:45
To: Dan Lear
Subject: Re: [Geoserver-users] WAR installation problems on Tomcat[Virus
Scanned by MBA]
Tomcat 5.
context
Can anyone help?
Many thanks,
Dan
Arne Kepp
Hi Dan,
I don't think i have ever seen this error before. If you could provide a bit more info it would be helpful in diagnosing the issue.
1. Which version of GeoServer are you running?
2. Which version of Java are you running?
3. Is there a full stack trace available in the log?
4. Does the application start, and then you get this error? Or does it happen during application startup?
-Justin
context
Can anyone help?
Many thanks,
Dan
Justin Deoliveira
