[Geoserver-users] Warning GEOS is NOT enabled
I recompiled postgis from scratch lately to support GEOS, which I compiled too. I confirm that GEOS’ bin directory is in my path.
When I start Geoserver I keep getting this warning message.
“[main] WARN org.geotools.data.postgis - GEOS is NOT enabled. This will result in limited functionality and performance.”
But I want GEOS working on that server. Why is it saying that if I compiled PostGIS besides GEOS?
Below is the result of my config command. I did a “make clean” then I recompiled PostGIS after that. Then relaunched PostGIS and Geoserver.
And I still got this message.
Checking for gcc… gcc
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking for g++… g++
checking whether we are using the GNU C++ compiler… yes
checking whether g++ accepts -g… yes
checking whether ln -s works… yes
checking for iconv_open in -liconv… no
checking for libiconv_open in -liconv… no
checking for iconv_open in -lc… yes
checking how to run the C preprocessor… gcc -E
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking iconv.h usability… yes
checking iconv.h presence… yes
checking for iconv.h… yes
checking build system type… i686-pc-linux-gnu
checking host system type… i686-pc-linux-gnu
checking for pg_config… /data/ulysse/postgis_geos/postgresql-8.2.4/bin/pg_config
checking for geos-config… /data/ulysse/postgis_geos/GEOS/bin/geos-config
checking for proj… /data/ulysse/postgis_geos/PROJ4/bin/proj
checking for flex… /usr/bin/flex
checking for dllwrap… no
checking for dlltool… no
checking for bison… bison -y
checking for perl… /usr/bin/perl
checking for xsltproc… no
checking for pdfxmltex… no
checking for db2pdf… no
checking for jw… no
checking which template to use… linux
configure: creating ./config.status
config.status: creating Makefile.config
config.status: WARNING: Makefile.config.in seems to ignore the --datarootdir setting
config.status: creating config.h
config.status: config.h is unchanged
SUMMARY
HOST_OS: linux-gnu
PGSQL: /data/ulysse/postgis_geos/postgresql-8.2.4/bin/pg_config
GEOS: /data/ulysse/postgis_geos/GEOS/bin/geos-config (with C-API)
(ldflags: -L/data/ulysse/postgis_geos/GEOS/lib)
PROJ: prefix=/data/ulysse/postgis_geos/PROJ4 libdir=/data/ulysse/postgis_geos/PROJ4/lib
ICONV: 1
PORTNAME: linux
PREFIX: /data/ulysse/postgis_geos/postgis
EPREFIX: ${prefix}
DOC: ${prefix}/share/doc
DATA: ${datarootdir}
MAN: ${datarootdir}/man
BIN: ${exec_prefix}/bin
EXT: ${exec_prefix}/lib (${exec_prefix}/lib)
Any opinion? :slight_smile:
Thanks in advance,
-Marc
Hi Marc,
What does the output of "select postgis_version()" give you when you run it against your db?
-Justin
Marc Desharnais wrote:
I recompiled postgis from scratch lately to support GEOS, which I compiled too. I confirm that GEOS' bin directory is in my path.
"[main] WARN org.geotools.data.postgis - GEOS is NOT enabled. This will result in limited functionality and performance."
Below is the result of my config command. I did a "make clean" then I recompiled PostGIS after that. Then relaunched PostGIS and Geoserver.
Checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether ln -s works... yes
checking for iconv_open in -liconv... no
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for pg_config... /data/ulysse/postgis_geos/postgresql-8.2.4/bin/pg_config
checking for geos-config... /data/ulysse/postgis_geos/GEOS/bin/geos-config
checking for proj... /data/ulysse/postgis_geos/PROJ4/bin/proj
checking for flex... /usr/bin/flex
checking for dllwrap... no
checking for dlltool... no
checking for bison... bison -y
checking for perl... /usr/bin/perl
checking for xsltproc... no
checking for pdfxmltex... no
checking for db2pdf... no
checking for jw... no
checking which template to use... linux
SUMMARY
HOST_OS: linux-gnu
   ICONV: 1
PORTNAME: linux
  EPREFIX: ${prefix}
Thanks in advance,
-Marc
!DSPAM:4007,46a0cd95215513362379201!
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Justin,
I speak for itself :
#select postgis_version();
            postgis_version
1.2 USE_GEOS=0 USE_PROJ=0 USE_STATS=1
(1 row)
How can I change that?
Thanks :slight_smile:
Marc
Justin Deoliveira wrote:
Hi Marc,
-Justin
Hmm... strange... this definitley indicates that geos and proj are not activated on your database... but the config log shows that they are there...
Looking at the configuration output i notice that GEOS and PROJ do not seem to be installed on "well known" locations... they seem to be referenced under your postgis sources? I wonder if the shared libraries (.so's) are not being found.
When you installed them did you do the full make install?
-Justin
ps. You might get a better answer on the postgis-users list as well.
Hi Justin,
           postgis_version
(1 row)
Marc
Hi Marc,
-Justin
Justin Deoliveira
