Ok thanks, I think it’s just that most of the data is based on OS Mastermap and just be to be cautious we put the watermark on with the copyright statement.
I just did a quick test on our local intranet install and it behaves the same, but a quick server restart has sorted that one out. The INSPIRE one is externally hosted so hopefully I can ask for it to be restarted and test the theory.
Hi Sandra,
For our INSPIRE compliance the only thing we’ve stuck watermarks on is the PSMA Ordnance Survey Stuff (so MasterMap, VML, 25k and 50k rasters). No other watermarks as they’re not necessary as best we can tell; the OS have seen our implementation and seem ok with it. I prefer the “minimum necessary” interpretation, but I’m quite anti-license.
Jonathan
On 4 December 2013 15:44, Sandra Kennish <s.kennish@anonymised.com> wrote:
Hi Jonathan
Thanks for the reply. We have considered that for our mapping server, but this server is purely for INSPIRE so we’re only serving out a WMS/WFS feed for that. To be honest I’m not even sure whether a watermark is necessary, just wanted it all to be watertight with OS.
Regards
Sandra Kennish
GIS Officer
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Sent: 04 December 2013 15:42
To: Sandra Kennish
Subject: Re: [Geoserver-users] Watermark Issue
Hi Sandra,
Sounds like it may be a bug, but someone more authoritative will hopefully be able to address that point.
What I’ve done rather than set watermarks at the WMS level is to create a Watermark SLD. The only layers that require watermarks for us are all Ordnance Survey LayerGroups, so I just add that watermark SLD to the layergroup. That may work as an alternative solution for you.
Jonathan
On 4 December 2013 15:03, Sandra Kennish <s.kennish@anonymised.com5737…> wrote:
Hi
I’m hoping someone can help with a problem with watermarks on WMS in Geoserver.
We have several workspaces set up with WMS information set at the individual workspace level – so different information in each workspace WMS – around 10 in total. We would like to set up watermarks – a different watermark for each workspace WMS. So we have setup 3 workspaces with different watermarks, but each one we try and set up afterwards doesn’t save the setting and over writes the WMS setting at the top level, which then cascades through to the rest of the workspaces, but not the first three we set up which retain their individual settings.
Is there a limit to how many workspaces we can set up with individual watermark settings?
Appreciate any pointers
Thank you
Sandra
Sandra Kennish
GIS Officer
North York Moors National Park Authority
The Old Vicarage
Bondgate
Helmsley
York
YO62 5BP
Tel: 01439 772700
Mobile: 07813 789126
www.northyorkmoors.org.uk
CONFIDENTIALITY: The contents of this message are the views of the author, not necessarily the views of the North York Moors National Park Authority. This is a private message intended for the named addressee(s) only. Its contents may be confidential.
If you have received this message in error please reply to say so and then delete the message. Any use, copying, disclosure or distribution by anyone other than the addressee is forbidden.
Scanned by MailDefender - managed email security from intY - www.maildefender.net
Sponsored by Intel(R) XDK
Develop, test and display web and hybrid apps with a single code base.
Download it for free now!
http://pubads.g.doubleclick.net/gampad/clk?id=111408631&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
