I’m running in to some issues with water marking - if I specify my watermark on the Layer/ Publish tab the GeoServer can see the image and correctly guesses the size and image type but nothing shows up in layer preview. If I set the same image in the global WMS settings page then it shows up in a single tile but when I switch to tiling it seems to only show up in the center tile of the meta tile set. This happens with both 2.4.3 and 2.5 beta but the only references I can find on line are http://jira.codehaus.org/browse/GEOS-3107 which claims to have fixed this problem some time ago.
Any ideas? I’d really like to only water mark a single layer (or layer group) but I’ll settle for a whole server if it watermarks all the tiles (I have to cover 10% of the displayed map so fixed tiles seems easiest).
cheers
Ian
Ian Turton
Hi Ian,
I have a transparent Polygon that covers the entire UK which has a style similar to a watermark. I then add that to a layergroup which has the one or two layers I want to watermark in it. This works quite well and means I don’t need to watermark all of my datasets.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
cheers
Ian
Ian Turton
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
On Tue, Feb 18, 2014 at 12:31 PM, Ian Turton <ijturton@anonymised.com> wrote:
I'm running in to some issues with water marking - if I specify my
Any ideas? I'd really like to only water mark a single layer (or layer
group) but I'll settle for a whole server if it watermarks all the tiles (I
Don't believe we ever had a way to put watermark on every tile when using
meta-tiling.
And not sure it makes sense either, if you are seeding an external tile
cache it will make 4x4 or larger
requests regardless, and the slice it, giving you the same result as what
we have internally.
Maybe what you want is a way to repeat the watermak every x pixels in the
output image instead.
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
meta-tiling.
we have internally.
That does make sense (though the jira suggests otherwise) - So I guess I
probably do want a repeat option, I'll probably follow Jonathon's polygon
method for the time being.
Any idea why setting the water mark on the layer publish tab doesn't work?
Ian
Actually it looks like once upon a time we (well you) did do this - http://grepcode.com/file/repo1.maven.org/maven2/org.geoserver/wms/1.7.0/org/vfny/geoserver/wms/responses/map/metatile/MetatileWatermarkPainter.java
Ian
On 18 February 2014 12:11, Ian Turton <ijturton@anonymised.com> wrote:
Ian Turton
That does make sense (though the jira suggests otherwise) - So I guess I probably do want a repeat option, I’ll probably follow Jonathon’s polygon method for the time being.
Any idea why setting the water mark on the layer publish tab doesn’t work?
Ian
Don’t believe we ever had a way to put watermark on every tile when using meta-tiling.
And not sure it makes sense either, if you are seeding an external tile cache it will make 4x4 or larger
requests regardless, and the slice it, giving you the same result as what we have internally.
