[Geoserver-users] Watermarking
“ image which cannot be edited, manipulated, interrogated, georeferenced or customised in any way or used
within any geographical information system or comparable database or software system) or
hard copy.”
They underestimate us or has anybody ever seen such an image really?
-Jukka Rahkonen-
Jonathan Moules wrote:
Heading offtopic from GeoServer here, but, looking at the notes from the PSMA user groups in March, it seems they’ve updated the PSMA license to not require watermarking:
“Watermarking
12.1.2 (b) For the avoidance of doubt, no
watermarking is required where the Licensee
makes Licensed Data available via electronic
documents (e.g. a pdf), static internet image (i.e.
a ‘read only’ raster format image which cannot
hard copy.”
Which is nice, except for those of us who spent the time doing it already. :-S
Sent: Wednesday, August 12, 2015 4:25 PM
To: ‘Kirk, Victor’; ‘geoserver-users@lists.sourceforge.net’
Subject: Re: [Geoserver-users] Watermarking
Hi Vic,
No problem, you’re quite welcome.
However, while the OS have their faults with regards to overzealous licensing requirements, generally they don’t seem to care if it actually is every tile. Certainly the site we created we made them aware of (they even used it as a case study!) and we used the method as below and it probably doesn’t cover every tile.
Oh yes, be sure to set a max scale so it only appears on OS MasterMap and not all of the other products in your zoom stack.
You can see it in action here (zoom to 1:5000 or closer): http://maps.warwickshire.gov.uk/
Jonathan
Sent: Tuesday, August 11, 2015 4:16 PM
To: ‘geoserver-users@lists.sourceforge.net’
Sorry, I completely forgot to thank you for the reply, it came in just as I was leaving for a few days and I’ve only just got back to looking at this issue.
I’ve tried what you suggested but my interpretation of the licensing requires each tile requires a watermark. The images rendered with this method only contain part of the watermark, or sometime none if the tile size is small enough.
I did look at using a layout (thinking I could add the layout parameter at the proxy server) but I could not see anyway of dynamically setting the size of the logo so it filled 10% of the tile.
Are there other tricks I could use? To summarise the my goal, render a graphic that fills a percentage of the requested tile at a particular zoom level.
Sent: 18 June 2015 17:03
To: Kirk, Victor; ‘geoserver-users@lists.sourceforge.net’
Subject: RE: Watermarking
Hi Vic,
I know this has come up before, but a quick search isn’t finding it.
Watermarking is fairly easy. The way I did it if memory serves;
  • Create a shapefile covering the entirety of the UK.
  • Style the shapefile with the watermark so that only the watermark is visible and somewhat transparent (20%?).
  • Use the watermark as the “top” layer in a layergroup with any of your OS datasets.
It works quite well and gets included in all outputs, WMTS, WMS, cached or otherwise.
You can see it in action here when you zoom in to 1:5k or closer.
Jonathan
Sent: Friday, June 12, 2015 11:02 AM
Subject: [Geoserver-users] Watermarking
I’m currently working with a dataset whose licensing requires a watermark. The watermark is to cover 10% of the rendered image. This data only required when zoomed right in. I couldn’t find a way of doing this in Geoserver so I’ve made a modification to the watermarking to accept a zoom level and a ratio of the tile to resize the watermark logo to.
The dataset in question is Ordinance Survey’s Master Map, so I’m sure other people must face similar watermark restrictions.
Is there a way of doing the above with Geoserver and if not, is there a better way of implementing my changes as a plugin rather than the core? Lastly, if the answer to both of these is no, would such a change be of enough interest to warrant pursuing incorporation into Geoserver’s code base.
Kind Regards,
Vic
Cubic Transportation Systems
Victor Kirk
Lead Developer
Cubic Transportation Systems (ITMS) Ltd
+44 1642 636894
cts.cubic.com
NextCity
RSS
Facebook
Twitter
LinkedIn
YouTube
Joint Winner, Best Bank Card Ticketing Scheme
MasterCard Transport Ticketing Awards 2015
Joint Winner, Most Innovative Transport Project
London Transport Awards 2015
Winner, 2014 CONNECT Awards Most Innovative New Product
Communications & IT category for NextBus Fleet Management Application
Winner, 2014 Australian Smart Infrastructure Award, Opal Card
Co-Winner, ITS-NY Project of the Year, MTA Bus Time****®
This document is intended for, and should only be read by, those persons to whom it is addressed. Its contents are confidential and if you have received this message in error, please delete it. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without our prior written consent is strictly prohibited.
Any views expressed in this message are those of the individual sender, and do not necessarily represent the position of Cubic Transportation Systems (ITMS) Limited (‘CTS’). Furthermore CTS does not authorise or use e-mail for official contractual correspondence. Nothing received in e-mail has any contractual validity.
CTSL and each legal entity in Cubic Corporation reserve the right to monitor all e-mail communications through its networks.
Registered Office:
Cubic Transportation Systems Ltd
AFC House
Honeycrock Lane
Salfords
Surrey
RH1 5LA
United Kingdom
Registered in England under number 8498086
This message has been scanned for viruses by MailControl, a service from BlackSpider Technology
Click here to report this email as spam.
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
Hi Jukka,
Yes, that’s standard in the PSMA license, the lawyers don’t really understand the technology. If you know about the technology and how to use it it’s pretty much impossible to comply with the text of the license.
If I remember correctly, there’s a similar bit somewhere that used to say (not sure if it’s still there) that you can’t share certain datasets via a web-service (WMS) that others would be able to use (i.e., in their QGIS, or their own OpenLayers thing). But you could use that data in your own public web-services (OpenLayers-esque) application. Needless to say a few seconds with Fiddler or Firebug etc and anyone can use your web-services in any way they want.
What we have in the Britain is central govt (I forget which department) paying central govt (Ordnance Survey) to let local govt (county councils and the like) to “freely” use data that the taxpayer has already paid for the creation of, and do so under a long and complex license agreement that takes a bunch of time and effort to comply with (speaking from experience).
There’s a lot to be said for the US model of: “the taxpayer paid for it already so it’s public domain, do what you want with it”.
Jonathan
From: Rahkonen Jukka (MML) [mailto:jukka.rahkonen@…6847…]
Sent: Thursday, August 13, 2015 1:29 PM
To: Jonathan Moules; ‘Kirk, Victor’; ‘geoserver-users@lists.sourceforge.net’
Subject: Re: Watermarking
hard copy.”
-Jukka Rahkonen-
“Watermarking
hard copy.”
Hi Vic,
Jonathan
Hi Vic,
Jonathan
Kind Regards,
Vic
Victor Kirk
Lead Developer
+44 1642 636894
cts.cubic.com
NextCity
RSS
Facebook
Twitter
LinkedIn
YouTube
Registered Office:
AFC House
Honeycrock Lane
Salfords
Surrey
RH1 5LA
United Kingdom
