[Geoserver-users] WCS 1.0.0 bug?
I did test with WCS 1.0.0 and the advertised format in DescribeCoverage is format=ARCGRID. What happens is:
http://localhost:8080/geoserver/wcs?service=WCS&version=1.0.0&request=getcoverage&CRS=EPSG:32633&BBOX=347649,5176214,370725,5196961&WIDTH=100&HEIGHT=100&coverage=nurc:Pk50095&format=ARCGRID
Result:
Could not find encoder for output format ARCGRID
This one with format=ArcGrid sends data:
http://localhost:8080/geoserver/wcs?service=WCS&version=1.0.0&request=getcoverage&CRS=EPSG:32633&BBOX=347649,5176214,370725,5196961&WIDTH=100&HEIGHT=100&coverage=nurc:Pk50095&format=ArcGrid
-Jukka Rahkonen-
Andrea Aime wrote:
On Mon, Jun 16, 2014 at 4:04 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@…486…> wrote:
It is a bug. Could you create a ticket into https://jira.codehaus.org/browse/GEOS? I confirmed the behaviour with Geoserver 2.5.
I haven’t checked, but is it really?
WCS 1.1 as far as I remember is supposed to work only with mime types, ARCGRID is not.
The way it should be:
  • ARCGRID is reported in wcs 1.0 capabilites document and it’s usable in 1.0
  • ARCGRID is not reported in wcs 1.1 and 2.0 capabilities document, and it’s not usable in those versions of the protocol
If we are violating the above then yes, there is a bug.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Jun 16, 2014 at 4:30 PM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
Result:
<?xml version="1.0" encoding="UTF-8"?><ServiceExceptionReport
version="1.2.0" > <ServiceException>
</ServiceException></ServiceExceptionReport>
Right, then it is a confirmed bug
Ing. Andrea Aime
@geowolf
Technical Lead
I've created an issue. Thanks for your responses.
Best regards,
Nhan
On 6/16/2014 4:40 PM, Andrea Aime wrote:
On Mon, Jun 16, 2014 at 4:30 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com <mailto:jukka.rahkonen@anonymised.com>> wrote:
    Result:
Ing. Andrea Aime
@geowolf
Technical Lead
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
