Dear GeoServer users,
could you please suggest me a way, how to set up a WCS service based on shapefiles? Do I need to convert my vector data to raster? Which is the suggested way to do so?
Thanks a lot in advance,
Op10
Op10
What is your goal? To display maps, serve data, or both?
Alex
suggested way to do so?Thanks a lot in advance,
Op10
------------------------------------------------------------------------------_______________________________________________
Geoserver-users mailing list
Both. I know how to set up a WMS, but it is not clear how to create a WCS
server that allows DOWNLOADing of GeoTiff data which are generated
from vector data.
Op10
-----Original Message-----
From: Alexander Petkov [mailto:greenkov@anonymised.com]
Sent: 2009. április 4. 18:04
To: op10@anonymised.com
Subject: Re: [Geoserver-users] WCS based on shapefiles?
Alex
the suggested way to do so?Thanks a lot in advance,
Op10
from vector data.
Op10
You'd have to rasterize your vector data in advance, prior to serving
it, and configure the rasters as Geoserver coverages.
GDAL has a vector to raster utility:
http://gdal.org/gdal_rasterize.html
Alex
I think that this is going too complicated with prerasterizing vectors. Geoserver WMS can already do the rasterizing. I would prepare well defined WMS requests with balanced bbox and image size, save the images on disk and after that convert them to GeoTIFFs. With Geoserver there is a need to make some simple system for generating a world file for each GetMap request.
With Mapserver your task would be simple. Just configure an additional GeoTIFF output format in the mapfile and then Mapserver could deliver directly Geotiffs with WMS requests.
-Jukka Rahkonen-
from vector data.
Op10
Alex
Rahkonen Jukka ha scritto:
GeoServer can generate GeoTIFF from WMS out of the box. The list
of supported output formats probably grew a little since you
last checked, here it is (there are some aliases in the middle):
<Format>image/png</Format>
<Format>application/atom xml</Format>
<Format>application/atom+xml</Format>
<Format>application/openlayers</Format>
<Format>application/pdf</Format>
<Format>application/rss xml</Format>
<Format>application/rss+xml</Format>
<Format>application/vnd.google-earth.kml</Format>
<Format>application/vnd.google-earth.kml xml</Format>
<Format>application/vnd.google-earth.kml+xml</Format>
<Format>application/vnd.google-earth.kmz</Format>
<Format>application/vnd.google-earth.kmz xml</Format>
<Format>application/vnd.google-earth.kmz+xml</Format>
<Format>atom</Format>
<Format>image/geotiff</Format>
<Format>image/geotiff8</Format>
<Format>image/gif</Format>
<Format>image/jpeg</Format>
<Format>image/png8</Format>
<Format>image/svg</Format>
<Format>image/svg xml</Format>
<Format>image/svg+xml</Format>
<Format>image/tiff</Format>
<Format>image/tiff8</Format>
<Format>kml</Format>
<Format>kmz</Format>
<Format>openlayers</Format>
<Format>rss</Format>
However, even using GeoTiff you'd end up with a georeferenced
RGBA image, whilst the usual vector rasterizing involves taking an
attribute of interest and generating a raster whose cell values have
that attribute. This is not possible with WMS, seems more the
work of a WPS.
Andrea Aime
OpenGeo - http://opengeo.org
Sorry, I must have one day a look at Geoserver as WMS server as well, not only WFS.
If the final goal is to have GeoTIFFs then one alternative could be to use GDAL as WMS client.
For me this looks interesting:
http://gdal.org/frmt_wms.html
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: Andrea Aime [mailto:aaime@anonymised.com]
Lähetetty: su 5.4.2009 10:51
Vastaanottaja: Rahkonen Jukka
Kopio: Alexander Petkov; op10@anonymised.com; geoserver-users@anonymised.com.net
Aihe: Re: [Geoserver-users] WCS based on shapefiles?
work of a WPS.
Andrea Aime
Nice idea!
Thanks to all of you for your tips!
Op10
From: Rahkonen Jukka [mailto:Jukka.Rahkonen@anonymised.com]
Sent: 2009. április 5. 11:09
To: Andrea Aime
Cc: Alexander Petkov; op10@anonymised.com;
only WFS.
GDAL as WMS client.
-Jukka-
GeoServer can generate GeoTIFF from WMS out of the box. The list of
supported output formats probably grew a little since you last checked, here
However, even using GeoTiff you'd end up with a georeferenced RGBA image,
whilst the usual vector rasterizing involves taking an attribute of interest
and generating a raster whose cell values have that attribute. This is not
possible with WMS, seems more the work of a WPS.
Andrea Aime
