[Geoserver-users] WCS - "coverage not found"
Hi Folks,
I have a file-based pyramid coverage I nabbed from http://etch.opengeo.org/bluemarble/ (bluemarble00), and I’ve added it to GeoServer. It serves fine over OpenLayers and KML, so now I’m trying to extract data directly using WCS.
The URL I’m using is:
http://:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&identifier=j2:pyramid&SERVICE=wcs&FORMAT=image/geotiff&boundingbox=-180,-90,-170,-80,urn:ogc:def:crs:EPSG::4326
I know there’s data at those co-ords, yet it returns this error:
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionText
java.io.IOException: The requested coverage could not be found.
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Which isn’t the same as saying there is no data at those co-ords. That error is this (I changed to a different dataset (single GeoTiff) to test):
ows:ExceptionText
The Intersection is null. Check the requested BBOX!
</ows:Exception>
And it can’t be because it can’t find the coverage itself because if I change the “identifier” to a made up one, it gives this error:
<ows:Exception exceptionCode=“InvalidParameterValue” locator=“identifier”>
ows:ExceptionTextCould not find coverage 'j2:outtsif'</ows:ExceptionText>
</ows:Exception>
The question then is, what does “java.io.IOException: The requested coverage could not be found.
The requested coverage could not be found.” actually mean, and how do I get my data served by WCS?
Jonathan
Hi Jonathan,
Cryptic indeed. Can you enable verbose logging and include the entire stack trace of the error. It would help to have a little context as to where exactly this is occurring. Thanks.
-Justin
Jonathan Moules wrote:
Hi Folks,
I have a file-based pyramid coverage I nabbed from http://etch.opengeo.org/bluemarble/ (bluemarble00), and I've added it to GeoServer. It serves fine over OpenLayers and KML, so now I'm trying to extract data directly using WCS.
The URL I'm using is:
http://<host>:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&identifier=j2:pyramid&SERVICE=wcs&FORMAT=image/geotiff&boundingbox=-180,-90,-170,-80,urn:ogc:def:crs:EPSG::4326 <http://%3chost%3e:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&identifier=j2:pyramid&SERVICE=wcs&FORMAT=image/geotiff&boundingbox=-180,-90,-170,-80,urn:ogc:def:crs:EPSG::4326>
I know there's data at those co-ords, yet it returns this error:
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>
</ows:Exception>
Which isn't the same as saying there is no data at those co-ords. That error is this (I changed to a different dataset (single GeoTiff) to test):
<ows:ExceptionText>
</ows:Exception>
<ows:Exception exceptionCode="InvalidParameterValue" locator="identifier">
<ows:ExceptionText>Could not find coverage &apos;j2:outtsif&apos;</ows:ExceptionText>
</ows:Exception>
The question then is, what does "java.io.IOException: The requested coverage could not be found.
The requested coverage could not be found." actually mean, and how do I get my data served by WCS?
Jonathan
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Done. Opened bug 3222 (I know it may not be a bug, but 2,300 lines of log-output may be a bit much for a mailing list :wink: ).
Jonathan
2009/7/2 Justin Deoliveira <jdeolive@anonymised.com>
Hi Jonathan,
-Justin
Hi Folks,
http://:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&identifier=j2:pyramid&SERVICE=wcs&FORMAT=image/geotiff&boundingbox=-180,-90,-170,-80,urn:ogc:def:crs:EPSG::4326 http://<host>:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&identifier=j2:pyramid&SERVICE=wcs&FORMAT=image/geotiff&boundingbox=-180,-90,-170,-80,urn:ogc:def:crs:EPSG::4326
ows:ExceptionText
</ows:Exception>
ows:ExceptionText
</ows:Exception>
</ows:Exception>
Jonathan
Justin Deoliveira
Thanks for being courteous to the list :slight_smile: So the error message indicates that there is an error actually doing the I/O and reading the coverage. I am far from a raster export so hopefully someone more raster knowledgeable can provide more insight.
Alternatively you can provide some of the data and we can try to walk through and actually debug what is happening.
-Justin
Hi Justin,
Jonathan
2009/7/2 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
    Hi Jonathan,
    -Justin
        Hi Folks,
        <ows:ExceptionText>
        </ows:Exception>
        <ows:ExceptionText>
        </ows:Exception>
          And it can't be because it can't find the coverage itself
        because if I change the "identifier" to a made up one, it gives
        this error:
        </ows:Exception>
        Jonathan
        <mailto:Geoserver-users@lists.sourceforge.net>
    -- Justin Deoliveira
    OpenGeo - http://opengeo.org/&gt;
Justin Deoliveira
Hi Justin,
The data is already on the web - as noted in my original message, I nabbed some pre-made pyramids from http://etch.opengeo.org/bluemarble/ - specifically “bluemarble00”. Beyond that I didn’t do anything, so now the list has as much info as I do. :slight_smile:
Jonathan
2009/7/4 Justin Deoliveira <jdeolive@anonymised.com>
-Justin
Hi Justin,
Jonathan
2009/7/2 Justin Deoliveira <jdeolive@anonymised.com71… mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>
Hi Jonathan,
-Justin
Hi Folks,
ows:ExceptionText
</ows:Exception>
ows:ExceptionText
</ows:Exception>
this error:
</ows:Exception>
Jonathan
Geoserver-users@anonymised.com.sourceforge.net
mailto:[Geoserver-users@anonymised.comrceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
– Justin Deoliveira
OpenGeo - http://opengeo.org <http://opengeo.org/>
Justin Deoliveira
