[Geoserver-users] WCS: different coverage identifiers in GetCapabilities and DescribeCoverage
Dear all,
I am working on an application that uses coverages from different
services. I am using WCS 1.1.1, that is kind of supported by both
MapServer and GeoServer.
For each coverage I must fetch information on the available CRSs, the
WGS84 bounding box and so forth. MapServer reports all this metadata
in the DescribeCoverage response, but GeoServer spreads it between the
GetCapabilities and DescribeCoverage responses. Thus for Geoserver I
must execute both requests and then merge the metadata.
However, there is a major problem with the responses returned by
GeoServer: different coverage identifiers are reported in each
request.
Take for example the response to this GetCapabilities:
http://extragisqa.gent.be/geoserver/Gent/ows?SERVICE=WCS&VERSION=1.1.1&REQUEST=GetCapabilities
It advertises a coverage with the identifier "dsm2003":
<wcs:CoverageSummary>
<ows:Title>DSM Gent 2003 2.5m</ows:Title>
<ows:Abstract>Generated from GeoTIFF</ows:Abstract>
<ows:Keywords>
<ows:Keyword>WCS</ows:Keyword>
<ows:Keyword>GeoTIFF</ows:Keyword>
<ows:Keyword>DSM_ghent_2.5m_buildings_2003</ows:Keyword>
</ows:Keywords>
<ows:WGS84BoundingBox>
<ows:LowerCorner>3.552395176113043 50.972191859666644</ows:LowerCorner>
<ows:UpperCorner>3.8693954783075153 51.1896845261209</ows:UpperCorner>
</ows:WGS84BoundingBox>
<wcs:Identifier>dsm2003</wcs:Identifier>
</wcs:CoverageSummary>
Then issuing a DescribeCoverage request:
http://extragisqa.gent.be/geoserver/Gent/ows?SERVICE=WCS&VERSION=1.1.1&REQUEST=DescribeCoverage&IDENTIFIERS=dsm2003
This coverage is now identified as "Gent:dsm2003":
<wcs:CoverageDescription>
<ows:Keywords>
</ows:Keywords>
<wcs:Identifier>Gent:dsm2003</wcs:Identifier>
With different identifiers it is not possible to merge the metadata.
For starters, I would like to know if there is a way to fix this.
Could this be caused by something wrong with the configuration? Or is
it a bug? Could an upgrade solve it? I do not have direct access to
this GeoServer instance, but it seems to be running version 6.4.3.
A secondary question would concern the spread of metadata across both
responses. Why isn't information such as the WGS84 bounding box, for
instance, reported in the DescribeCoverage response?
Any clarifications are welcome. Thank you for reading,
Luís
On Thu, May 21, 2015 at 10:52 AM, Luís de Sousa <luis.a.de.sousa@anonymised.com...>
wrote:
Dear all,
request.
<ows:Keywords>
</ows:Keywords>
<ows:Keywords>
</ows:Keywords>
it a bug?
Looks like a bug, the code is doing two different things in the two places.
No, the current code still has the issue
Don't think there is a significant choice made there, it just happened, and
as
far as I know, it's valid behavior. A client should not make assumptions
that
everything is in one place, but if you want, you can make a pull request
to change the current code and put everything you need in the capabilities.
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello again,
Starting from the finish, I went through the WCS 1.1.1 document and in
fact the WGS84BoundingBox element is not part of the Domain data
structure in CoverageDescription. Even though it is far more useful
that way, the inclusion by MapServer of this element in the response
to DescribeCoverage is non compliant. However, MapServer does not
officially support WCS 1.1.1, only 1.1.0.
In essence, to access all the metadata for a coverage one really needs
to merge both response documents. Thus the identifiers must match.
This is now reported as issue 7039:
https://osgeo-org.atlassian.net/browse/GEOS-7039
Luís
it a bug?
as
that
