[Geoserver-users] WCS GetCapabilities version/acceptversion
I am trying to use QGIS as a WCS client against a GeoServer instance. The first thing QGIS does is to attempt to get the capabilities document, i.e.:
http://hostname/geoserver/wcs?SERVICE=WCS&REQUEST=GetCapabilities&AcceptVersions=1.1.0,1.0.0
However this causes an exception on GeoServer 2.6.1 (on linux):
Caused by: javax.xml.transform.TransformerException: java.lang.IllegalArgumentException: Not a GetCapabilitiesType: net.opengis.wcs20.impl.GetCapabilitiesTypeImpl@anonymised.com (updateSequence: null, baseUrl: http://sumi:8686/geoserver/) (service: WCS)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:755)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:359)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wcs2_0.response.WCS20GetCapabilitiesResponse.write(WCS20GetCapabilitiesResponse.java:69)
… 94 more
Caused by: java.lang.IllegalArgumentException: Not a GetCapabilitiesType: net.opengis.wcs20.impl.GetCapabilitiesTypeImpl@anonymised.com3… (updateSequence: null, baseUrl: http://sumi:8686/geoserver/) (service: WCS)
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:116)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:1026)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:677)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:746)
… 99 more
I guess this is because GeoServer expects the “Version” parameter (WCS 2.0) instead of the “AcceptVersions” parameter (WCS 1.0/1.1). Is there a way to force GeoServer to use the WCS 1.0/1.1 syntax instead? I have tried editing wcs.xml but it always gets overwritten.
Tim
Hi Tim,
if we look at it in general terms (beyond the specifics of the WCS issue) this is not exactly an easy fix, due to the way GeoServer parses the requests.
In the Dispatcher class GeoServer first decides which service and version need to handle the request, and
the dispatches it.
Unfortunately, negotiation is not well build into the Dispatcher, and it fails to handle those parameters you’re citing… this is also
causing other issues, like picking up the wrong kvp parser, and so on.
I’ve beeing trying to solve this problem, in my spare time, since 2010:
https://osgeo-org.atlassian.net/browse/GEOS-4221
(the ticket has been migrated this year, the original version is here http://jira.codehaus.org/browse/GEOS-4221)
My latest attempt at fixing the issue is one year old:
https://github.com/geoserver/geoserver/pull/574
And well… after several attempts I’ve come to a realization… it’s not something I can manage to do in my spare time…
The problem is that changing the dispatcher has too many ramifications, and requires going over all the CITE
tests, so it ends up requiring too much time in a single uninterrupted session to be done in spare time.
Specifically for WCS, workarounds could be implemented, like making the WCS 2.0 capabilities kvp reader
understand also the wcs 1.1 and 1.0 syntax, which is a much smaller change, and then have the WCS 2.0
service learn to dispatch also back to 1.0… I mean, it’s feasible, it’s just not the clean solution imho
On Sat, May 30, 2015 at 10:10 AM, Tim Chan <TCHAN@anonymised.com> wrote:
… 94 more
… 99 more
Tim
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
