Hi, Using WCS sometimes I get the following error: “The specified dimensional parameter is non-positive”. I have been testing with a lot of requests and It seems to me that that error is due to the fact that the specified area is not big enough.Is it right? In such a case, What is the minimum area that can be specified for a BoundingBox? Thanks in advance |
Antonio Diaz Sanchez ha scritto:
Using WCS sometimes I get the following error: "The specified dimensional parameter is non-positive". I have been testing with a lot of requests and It seems to me that that error is due to the fact that the specified area is not big enough.Is it right? In such a case, What is the minimum area that can be specified for a BoundingBox?
It may be, but a fuller stack trace would be helpful.
Please go in the GeoServer configuration, config/server, enable
verbose exceptions, apply/save, and do the request again.
What is the full stack trace you get?
The best would be if you could reproduce the error against one
of the same layers and you could share the request (so that we
can reproduce it)
Andrea Aime
OpenGeo - http://opengeo.org
