On Tue, Apr 14, 2015 at 2:24 AM, Danny Cheng <dcheng@anonymised.com>
wrote:
2. I found that WCS performance is really poor if my image mosaic layer
uses footprints to mask out blackfill. I presume the performance hit is
because GeoServer is generating the transparency layer on the fly. Is this
true?
Probably, but it must also be related to how complex your footprint
geometry is
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
