Hi Andrew,
in geotools we call this issue “pixel is center” vs " pixel is corner".
OGC mandates the “pixel is center” interpretation as far as I know, see also:
http://gis.stackexchange.com/questions/122670/is-there-a-standard-for-the-coordinates-of-pixels-in-georeferenced-rasters
http://mapserver.org/fr/development/rfc/ms-rfc-107.html
As far as I know, GeoTools tries to work “pixel is center” from beginning to end, and there
are no ways to control that, also, WCS follows the OGC interpretation strictly and does not
offer a way to return “pixel is corner” rasters, but I may be wrong.
I’m cc’ing Daniele, he should know more on this matter.
That said, especially in WCS 2.0, built to be extensible, one could put together a vendor profile that allows controlling
the pixel interpretation for the outputs.
On Tue, Mar 31, 2015 at 11:28 PM, Andrew Annex <aannex@anonymised.com> wrote:
Hello GeoServer users,
I am making wcs 1.0.0 requests for geotiffs against a coverage layer.
Does GeoServer support returning geotiffs via wcs that are “Point”
instead of “Area” pixels for the meta-data value: “AREA_OR_POINT”? This
metadata field is further explained here:
http://www.gdal.org/gdal_datamodel.html. By default the geotiff writer
assumes area, and that writer appears to be used in the
GeoTIFFCoverageResponseDelegate. Is there some way to set this as a hint
in the wcs query url or is there something I can overwrite when
extending the AbstractGridCoverage2DReader and/or the AbstractGridFormat
so that the ResponseDelegate will pick up on that hint? Although it may
not matter I am working with geoserver 2.5.2 / geotools 11.2.
Also if this question is more appropriate for the geotools user list let
me know.
Thanks - Andrew
- Andrew Annex, Data Scientist.
- (434)-284-9405 ext. 153
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
conversation now. [http://goparallel.sourceforge.net/](http://goparallel.sourceforge.net/)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
