[Geoserver-users] WCS return GeoTiff with point Pixels.
I believe that this is totally grey are in WCS 1.0.0 but for WCS 2.0 there seems to be two papers which are not official standards but maybe sort of recommendations:
https://portal.opengeospatial.org/files/?artifact_id=51141
https://portal.opengeospatial.org/files/?artifact_id=51142
From the first one you can read that both pixel is area and pixel is point are supported if GeoTIFF coverages:
Requirement 9 /req/geotiff-coverage/pixel-is-area: The domain of a coverage using GeoTIFF encoding shall respect the coverage’s raster space as defined in the GeoTIFF specification [GeoTIFF] i.e. in PixelIsArea the first pixel-value fills the square grid cell with the bounds top-left = (0,0), bottom-right = (1,1) and in PixelIsPoint the first pixel-value is realized as a point value located at (0,0).
I recommend to read the whole document but according to this excerpt the georeferencing info that is written as a rectified grid in GML will be slightly different for PixelIsArea and PixelIsPoint. The origin and offsetVectors are the same but the BoundedBy area is half a pixel wider to all directions for PixelIsArea than for PixelIsPoint.
Note The definition of grids in GML 3.2 [OGC 07-036] clause 19.2.2 which GMLCOV is based on reads as: “When a grid point is used to represent a sample space (e.g. image pixel), the grid point represents the center of the sample space (see ISO 19123:2005, 8.2.2).”. Image pixel in this GML quote denotes the same as image space in GeoTIFF terminology. In a gml:RectifiedGrid used with PixelIsArea this applies to the gml:origin element which is therefore shifted by half a gml:offsetVector in both dimensions compared to the gml:boundedBy element.
Note GMLCOV does not store the raster type i.e. PixelIsArea or PixelIsPoint information in its current version. However, Requirement 9 above specifies that the gml:boundedBy element shall respect the raster type i.e. it shall include the half pixel border in case of PixelIsArea (see also Figure 1).
-Jukka Rahkonen-
Andrea Aime wrote:
Hi Andrew,
in geotools we call this issue “pixel is center” vs " pixel is corner".
OGC mandates the “pixel is center” interpretation as far as I know, see also:
http://gis.stackexchange.com/questions/122670/is-there-a-standard-for-the-coordinates-of-pixels-in-georeferenced-rasters
http://mapserver.org/fr/development/rfc/ms-rfc-107.html
As far as I know, GeoTools tries to work “pixel is center” from beginning to end, and there
are no ways to control that, also, WCS follows the OGC interpretation strictly and does not
offer a way to return “pixel is corner” rasters, but I may be wrong.
I’m cc’ing Daniele, he should know more on this matter.
That said, especially in WCS 2.0, built to be extensible, one could put together a vendor profile that allows controlling
the pixel interpretation for the outputs.
On Tue, Mar 31, 2015 at 11:28 PM, Andrew Annex <aannex@…4616…> wrote:
Hello GeoServer users,
I am making wcs 1.0.0 requests for geotiffs against a coverage layer.
Does GeoServer support returning geotiffs via wcs that are “Point”
instead of “Area” pixels for the meta-data value: “AREA_OR_POINT”? This
metadata field is further explained here:
http://www.gdal.org/gdal_datamodel.html. By default the geotiff writer
assumes area, and that writer appears to be used in the
GeoTIFFCoverageResponseDelegate. Is there some way to set this as a hint
in the wcs query url or is there something I can overwrite when
extending the AbstractGridCoverage2DReader and/or the AbstractGridFormat
so that the ResponseDelegate will pick up on that hint? Although it may
not matter I am working with geoserver 2.5.2 / geotools 11.2.
Also if this question is more appropriate for the geotools user list let
me know.
Thanks - Andrew
  • Andrew Annex, Data Scientist.
  • (434)-284-9405 ext. 153
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
