[Geoserver-users] WCS: tiled coverage
I have some world-file-georeferenced images in a directory, and I want to make a single coverage out of it: is it possible ? And how ?
    Luca Morandini
www.lucamorandini.it
Hmm.... I thought it to be a fairly basic question: really no-one can answer this ?
    Luca Morandini
Ciao Luca,
sorry, but I missed the previous email.
The wcs branch should do what you need. I just implemented a plugin
for putting together a mosaic of georeferenced images.
These days I have been sick and I have not been at work. If you have a
bit of patience tomorrow I will write a more detailed email on how to
configure the ImageMosaic plugin and I I will also prepare an example.
I hope this is enough for the moment.
Simone.
Simone Giannecchini
Software Engineer
Freelance Consultant
http://simboss.wordpress.com/
"Canterò le mie canzoni per la strada
ed affronterò la vita a muso duro
un guerriero senza patria e senza spada
con un piede nel passato
e lo sguardo dritto e aperto nel futuro."
answer this ?
   Luca Morandini
This SF.Net email is sponsored by xPML, a groundbreaking scripting language
that extends applications into web and mobile media. Attend the live webcast
and join the prime developer group breaking into this new coding territory!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=110944&bid=241720&dat=121642
Geoserver-users mailing list
Simone Giannecchini wrote:
Ciao Luca,
Many thanks.
By the way, I have a couple questions more:
1) Have someone tried such a plugin with, say, 25GB of images (TIFF with world file) ?
2) Will the WCS support be released into GeoServer 1.4 ?
Thanks in advance :wink:
    Luca Morandini
Akkineni Vijay wrote:
Hi Luca,
                       I have a problem .. Is the tiling and deffered loading included in the current wcs branch of svn . and how do i get the latest wcs branch and compile it and make a war . can u help me.
Vijay Akkineni.
Ahem... this should be asked to Simone Giannecchini instead.
    Luca Morandini
> Hi Luca,
> Regards,
> Vijay Akkineni.
I remember vaguely that you already checked out the svn for the WCS
branch. If so, you can just update your local SVN copy. Could be as
simple as running "svn update", but that depends on your setup. Did
you, for example, use eclipse or the command line svn client?
Or am I way off in what I remember?
Alex
Ciao Luca,
answers inlined below,
> Ciao Luca,
Many thanks.
world file) ?
Well the answer is no but it really should not matter. Let me explain.
I assume that you are talking about hig res imagery, probably aerial
photos. If that is the case you won't be interested in showing all the
25 gb at a time but you will be interested in showing probably 5 or 6
tiles at a time. The way the plugin is built allows me to load only
the requested tiles from the all data set, hence playing with max
scale you can easyli have good perfomance even with a huge data set. I
have played around with 600 mb of data with an high scale and things
were pretty fast.
Of course the plugin will be improved by using for example overviews
in order to allow you to use less stringent limits for max scale, but
for the moment this was the most I had time to do.
I am a bit suspicious about the 1.4. I am going to ump in the
discussion this afternoon with a long email since I think that maybe
we are not spending all the enrgies in the right directions.
   Luca Morandini
Ciao Luca.
PS
Ho visto il tuo sito ed i progetti a cui lavori, i miei complimenti.
Chissa' che non si possa collaborare su qualcosa...
Simone Giannecchini
Software Engineer
Ciao Luca,
world file) ?
<cut/>
Yeah, I know the tiling trick... what I really meant was: has the WCS been tested under real-life conditions ?
The fact that is still labeled "experimental", makes me wonder if it could be used in a production environment.
PS
Lo spero anch'io :slight_smile:
Ciao,
    Luca Morandini
