is it possible to configure the download file format for a WCS request?
There is the FORMAT parameter (e.g. GeoTIFF, GIF, ...) in the WCS url but is
there anything more specific?
For example, when requesting GeoTIFF format, can I define the tiff tags such
as 0x103 - whch specifies the compression mode (it always seems to be
compressed) or geotag 1025 - GTRasterTypeGeoKey (which always seems to be
RasterPixelIsPoint rather than the more common RasterPixelIsArea)
These options are fixed on GeoServer and specifically depend from the
GeoTools GeoTIFF plugin, even because as far as I know there is no OGC
compliant way to specify different format options unless you use
something like vendor parameters.
On Thu, Jan 8, 2009 at 5:30 PM, djud <djud@anonymised.com> wrote:
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source. http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
