On Fri, Feb 20, 2015 at 10:37 AM, Roel De Nijs <roel.denijs@anonymised.com>
wrote:
Hi list,
I’m using Geoserver 2.6.2. Can you define/configure a sorting order for
the layers view in the web administration interface?
It seems the layers are sorted by default on workspace and store. But
maybe that’s just a coincidence and there is no sorting order defined. I
want to sort them on workspace, store and layer name.
The user interface only allows to sort on a single column, by clicking on
its header ,we don't have support
for multiple sorts.
I have in front of me the layer page source code from the 2.7.x series and
2.6.x series,
and as far as I can tell it has no built-in sorting (until you specify one
manually).
To get what you want you'd have to change the GeoServer code.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
