Hi-
I'm running GeoServer 2.5.2 on a Windows 2008 AWS instance. I've uploaded my
data properly and seemingly published my layers correctly.
However, when I test my map services using the public DNS the data doesn't
display.
http://ec2-54-183-153-46.us-west-1.compute.amazonaws.com:8080/geoserver/Arches/wms?service=WMS&version=1.1.0&request=GetMap&layers=Arches:CPEN_Boundary&styles=&bbox=-1.3090760425920812E7,3922616.837580707,-1.3052111348365875E7,3962348.662797804&width=498&height=512&srs=EPSG:3857&format=image%2Fpng
I've set my security groups to allow all traffic both inbound and outbound.
Please let me know if you can help.
MapZac
View this message in context: http://osgeo-org.1560.x6.nabble.com/Web-Mapping-Service-Unavailable-when-Linked-from-GeoServer-using-Amazon-EC2-tp5156042.html
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Your service seems to fail to respond to even just: http://ec2-54-183-153-46.us-west-1.compute.amazonaws.com:8080/geoserver/
So it maybe a tomcat/jetty config issue (whichever you’re using) or an AWS thing.
How did you configure the layers? Within GeoServer on AWS?
Jonathan
On 12 August 2014 21:08, zacstanley <zac.stanley@anonymised.com> wrote:
Hi-
I’m running GeoServer 2.5.2 on a Windows 2008 AWS instance. I’ve uploaded my
However, when I test my map services using the public DNS the data doesn’t
display.
I’ve set my security groups to allow all traffic both inbound and outbound.
MapZac
Geoserver-users mailing list
Hi Jonathan-
I configured in geoserver on the windows server instance through AWS.
I feel like it's something to do with the security group configuration in
AWS. I've been experimenting but continue to have no luck.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Web-Mapping-Service-Unavailable-when-Linked-from-GeoServer-using-Amazon-EC2-tp5156042p5156209.html
