Rejoice!! Great work Alessio. I am excited to check out your work.
What is the state of the struts app on your branch. I know you did some
work figuring out how to do similar modularization with struts. The
reason I ask is because it would be nice to have the modularity with the
current app without switching to a new technology and rewriting it.
While on the topic, I spoke briefly with Simone about this and it would
nice to hear your thoughts about merging trunk and wcs branch up soon.
Simone brought up the point that it would be easiest to make the wcs
branch the new trunk, as it is has been bringing changes across from
trunk and has been much more active. Similar what we did with the 1.4.x
branch.
I know you guys are busy at the moment, as am I. So I intend to do up a
GSIP for this issue, and perhaps target its implementation for after
FOSS. Any thoughts?
-Justin
Alessio Fabiani wrote:
Hi guys,
after several analysis and evaluations, finally I have created an
example Web UI for GeoServer, based on wicket, which is capable to
retrieve resources directly from the classpath, in order to let each
module to have his own Web UI inside the JAR.
With this improvement we can plug-in/out modules along with theyr
interfaces into GeoServer.
The module and the template, with some examples, is alredy available for
your evaluation in the 1.4.x WCS branch.
I will wirte a detailed report describing all the evaluations and
analysis made to reach this solution (as soon as possible).
Alessio.
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
!DSPAM:1004,44e98787201111429667743!
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
