Hello.
I am trying to access Geoserver through a servlet using the Geotools
library that comes with Geoserver package, and I have noticed that
initializing the WebMapServer class:
URL url = new URL("http://localhost:8080/geoserver/wms"\);
begin = System.currentTimeMillis();
WebMapServer wms = new WebMapServer(url);
end = System.currentTimeMillis();
takes quite a bit of time at 928 ms, since I believe it has to do a
GetCapabilities request first. Considering that getting a quite
detailed map takes only 145 ms from a GetMapRequest, the 928 ms seems
quite expensive.
Is this normal or am I doing something wrong.
Thanks.
Mario.
Mario Basa ha scritto:
Hello.
quite expensive.
It seems normal to me, you're parsing XML, which is quite a bit more
expensive than just rendering a map, plus the caps document contains
a huge list of SRS which probably affect the response times.
Suggestions:
- go into the WMS configuration and set a shorter list of EPSG codes
to return
- cache the WebMapServer object and reuse it for multiple requests
Andrea Aime
OpenGeo - http://opengeo.org
Thanks for the quick reply Andrea.
Just curious though, is there another class that can be used that
doesn't do a GetCapabilities during initialization?
Thanks again.
Mario.
Hello.
URL url = new
begin = System\.currentTimeMillis\(\);
WebMapServer wms = new WebMapServer\(url\);
end = System\.currentTimeMillis\(\);
quite expensive.
Suggestions:
to return
Andrea Aime
I don't think so, but if you explain why a one second initialization is so killer to your use case we can may be find out a solution? Isn't paying that initialization time once and reuse the WebMapServer instance for multiple requests acceptable?
regards,
Gabriel
Thanks again.
Mario.
Hello.
URL url = new
quite expensive.
Suggestions:
to return
Andrea Aime
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Hello Gabriel,
Again, I am planning to use this in a servlet setting and 1 full
second is expensive especially if you consider that getting a map
request (which is the purpose of the servlet) just takes ~143 ms.
Yes, I can probably reuse the object through the session, but I had
bad experience reusing objects before and would like to avoid doing so
as much as possible. Is the object thread-safe?
Mario.
On Tue, Mar 24, 2009 at 1:31 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
regards,
Gabriel
Thanks again.
Mario.
Hello.
URL url = new
quite expensive.
Suggestions:
to return
Andrea Aime
