Hi Everyone,
I have started a new thread on this, since it seems to be a bug with one of the nightly builds (August 8th I believe). I really need the Google Maps functionality that was included in this build, which by the way, seems to work absolutely brilliantly. However, I stumbled on another problem related to setting up spatial views in the datastore.
I get two distinctly different behaviours when I try and define a new feature type, that is based on a PostGIS view between these two versions.
The view is defined as follows:
CREATE OR REPLACE VIEW vw_avianflu_animals AS
SELECT admin2_centroids.gid, avainflu_animals.isocountry, avainflu_animals.country, avainflu_animals.lvl, avainflu_animals.lvlid AS lvlid_1, avainflu_animals.name, avainflu_animals.asatdate, avainflu_animals.datasource, avainflu_animals.noofcases, avainflu_animals.outbreaktype, avainflu_animals.dateoutbreakstarted, admin2_centroids.lvlid, admin2_centroids.the_geom AS geom
FROM admin2_centroids
JOIN avainflu_animals ON avainflu_animals.lvlid::text = admin2_centroids.lvlid::text
UNION
SELECT admin1_centroids.gid, avainflu_animals.isocountry, avainflu_animals.country, avainflu_animals.lvl, avainflu_animals.lvlid AS lvlid_1, avainflu_animals.name, avainflu_animals.asatdate, avainflu_animals.datasource, avainflu_animals.noofcases, avainflu_animals.outbreaktype, avainflu_animals.dateoutbreakstarted, admin1_centroids.lvlid, admin1_centroids.the_geom AS geom
FROM admin1_centroids
JOIN avainflu_animals ON avainflu_animals.lvlid::text = admin1_centroids.lvlid::text
ORDER BY 1;
ALTER TABLE vw_avianflu_animals OWNER TO postgres;
Bascially, I just join some thematic data to two spatial data tables and output that is a single layer. I originally thought that it may have had something to do with the UNION operator that I used, but that does not seem to be the problem. Anyway, version 1.5.2 correctly identifies the view SRS as 4326, and I am able to do a “Generate bounding box” and everything works just fine (I have output the log from Tomcat below, which does throw an exception, but seems to work anyway). However, with the nightly build, I am not able to instantiate the spatial view correctly, and the SRS is identified as -1. I cannot generate a bounding box and geoserver throws a number of errors (see below for ghastly details).
If I downgrade back to 1.5.2, and setup the view this way, the nightly build is able to display the view. Wacky huh? Anyway, this seems like a bug, and if you need more details, please let me know and I can try and help.
Also, I have tried adding the view to the PostGIS geometry_columns table, to no avail. The behaviour is the same in both instances, whether the view is defined in the PostGIS metadata table seems to make no difference.
Best regards,
Jason
1.5.2. release version on adding the view to the data store
java.lang.NullPointerException
at org.vfny.geoserver.config.DataConfig.getFeatureTypeIdentifiers (DataConfig.java:947)
at org.vfny.geoserver.form.data.DataFeatureTypesNewForm.getNewFeatureTypes(DataFeatureTypesNewForm.java:31)
at java.lang.reflect.Method.invoke (Method.java:597)
at org.apache.commons.beanutils.PropertyUtilsBean.invokeMethod(PropertyUtilsBean.java:1773)
at org.apache.commons.beanutils.PropertyUtilsBean.getSimpleProperty(PropertyUtilsBean.java :1132)
at org.apache.commons.beanutils.PropertyUtilsBean.getNestedProperty(PropertyUtilsBean.java:686)
at org.apache.commons.beanutils.PropertyUtilsBean.getProperty(PropertyUtilsBean.java:715)
at org.apache.commons.beanutils.PropertyUtils.getProperty(PropertyUtils.java:290)
at org.apache.struts.taglib.html.OptionsTag.getIterator(OptionsTag.java:371)
at org.apache.struts.taglib.html.OptionsTag.doEndTag (OptionsTag.java:243)
at org.apache.jsp.WEB_002dINF.pages.data.featureTypes.New_jsp._jspx_meth_html_options_0(New_jsp.java:202)
at org.apache.jsp.WEB_002dINF.pages.data.featureTypes.New_jsp._jspx_meth_html_select_0 (New_jsp.java:174)
at org.apache.jsp.WEB_002dINF.pages.data.featureTypes.New_jsp._jspx_meth_html_form_0(New_jsp.java:112)
at org.apache.jsp.WEB_002dINF.pages.data.featureTypes.New_jsp._jspService(New_jsp.java:75)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:94)
at org.apache.jasper.servlet.JspServletWrapper.service (JspServletWrapper.java:324)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:292)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:236)
at javax.servlet.http.HttpServlet.service (HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java :173)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:696)
at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:585)
at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:510)
at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:966)
at org.apache.jasper.runtime.PageContextImpl.include (PageContextImpl.java:602)
at org.apache.struts.tiles.TilesUtilImpl.doInclude(TilesUtilImpl.java:99)
at org.apache.struts.tiles.TilesUtil.doInclude(TilesUtil.java:135)
at org.apache.struts.taglib.tiles.InsertTag.doInclude (InsertTag.java:760)
at org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEndTag(InsertTag.java:892)
at org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag.java:462)
at org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspx_meth_tiles_insert_7 (mainLayout_jsp.java:1491)
at org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspService(mainLayout_jsp.java:619)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:324)
at org.apache.jasper.servlet.JspServlet.serviceJspFile( JspServlet.java:292)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter (ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java :696)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:474)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:409)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:312)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.doForward(MultipleDelegatingTilesRequestProcessor.java :372)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processTilesDefinition(MultipleDelegatingTilesRequestProcessor.java:217)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processForwardConfig (MultipleDelegatingTilesRequestProcessor.java:80)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:241)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at javax.servlet.http.HttpServlet.service(HttpServlet.java :802)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java :202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:214)
at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:104)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:520)
at org.apache.catalina.core.StandardContextValve.invokeInternal (StandardContextValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:152)
at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java :104)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137)
at org.apache.catalina.core.StandardValveContext.invokeNext (StandardValveContext.java:104)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:118)
at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:929)
at org.apache.coyote.tomcat5.CoyoteAdapter.service (CoyoteAdapter.java:160)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java :705)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run (Thread.java:619)
rest based on schemaBase: gml:AbstractFeatureType
Nightly build (August 8th 2007) version on adding the view to the data store
WARNING:
at org.vfny.geoserver.config.DataConfig.getFeatureTypeIdentifiers(DataConfig.java:950)
at sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:25)
at org.apache.commons.beanutils.PropertyUtilsBean.getSimpleProperty (PropertyUtilsBean.java:1132)
at org.apache.commons.beanutils.PropertyUtilsBean.getProperty(PropertyUtilsBean.java :715)
at org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspx_meth_tiles_insert_7 (mainLayout_jsp.java:1322)
at org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspService(mainLayout_jsp.java:617)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.doForward(MultipleDelegatingTilesRequestProcessor.java :346)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processTilesDefinition(MultipleDelegatingTilesRequestProcessor.java:212)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processForwardConfig (MultipleDelegatingTilesRequestProcessor.java:81)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java :274)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter (FilterChainProxy.java:274)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter (HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java :148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter (ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java :214)
13 Aug 08:07:36 WARN [data.jdbc] - Error building attribute type. The column will be ignored
org.geotools.data.DataSourceException: An exception occurred while parsing WKB data
at org.geotools.data.postgis.attributeio.PgWKBAttributeIO.WKB2Geometry (PgWKBAttributeIO.java:106)
at org.geotools.data.postgis.attributeio.PgWKBAttributeIO.read(PgWKBAttributeIO.java:178)
at org.geotools.data.postgis.PostgisDataStore.getGeometryAttribute(PostgisDataStore.java :1091)
at org.geotools.data.postgis.PostgisDataStore.buildAttributeType(PostgisDataStore.java:986)
at org.geotools.data.jdbc.JDBC1DataStore.buildSchema(JDBC1DataStore.java:1166)
at org.geotools.data.postgis.PostgisDataStore.buildSchema (PostgisDataStore.java:663)
at org.geotools.data.jdbc.FeatureTypeHandler.getFeatureTypeInfo(FeatureTypeHandler.java:197)
at org.geotools.data.jdbc.FeatureTypeHandler.getSchema(FeatureTypeHandler.java :165)
at org.geotools.data.jdbc.JDBC1DataStore.getSchema(JDBC1DataStore.java:319)
at org.geotools.data.postgis.PostgisDataStore.getSchema(PostgisDataStore.java:1929)
at org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute (DataFeatureTypesNewAction.java:83)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.doPost (ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java :264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java :72)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java :125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java :142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java :81)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter (SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.doFilter( ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke (StandardContextValve.java:152)
at org.apache.catalina.valves.ErrorReportValve.invoke (ErrorReportValve.java:118)
at org.apache.catalina.core.StandardPipeline.invoke (StandardPipeline.java:520)
at org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:160)
at org.apache.coyote.http11.Http11Processor.process (Http11Processor.java:799)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:705)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java :577)
at java.lang.Thread.run(Thread.java:619)
Caused by: com.vividsolutions.jts.io.ParseException: Unknown WKB type 65
at com.vividsolutions.jts.io.WKBReader.readGeometry(WKBReader.java:183)
at com.vividsolutions.jts.io.WKBReader.read(WKBReader.java:137)
at com.vividsolutions.jts.io.WKBReader.read(WKBReader.java :118)
at org.geotools.data.postgis.attributeio.PgWKBAttributeIO.WKB2Geometry(PgWKBAttributeIO.java:100)
… 66 more
at org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute (DataFeatureTypesNewAction.java:103)
at org.geotools.data.postgis.attributeio.PgWKBAttributeIO.WKB2Geometry(PgWKBAttributeIO.java:106)
at org.geotools.data.postgis.attributeio.PgWKBAttributeIO.read (PgWKBAttributeIO.java:178)
at org.geotools.data.postgis.PostgisDataStore.getGeometryAttribute(PostgisDataStore.java:1091)
at org.geotools.data.postgis.PostgisDataStore.buildAttributeType(PostgisDataStore.java :986)
at org.geotools.data.postgis.PostgisDataStore.buildSchema(PostgisDataStore.java:663)
at org.geotools.data.jdbc.FeatureTypeHandler.getFeatureTypeInfo (FeatureTypeHandler.java:197)
at org.geotools.data.jdbc.FeatureTypeHandler.getSchema(FeatureTypeHandler.java:165)
at org.vfny.geoserver.form.data.TypesEditorForm.reset(TypesEditorForm.java:283)
at org.apache.struts.taglib.html.FormTag.initFormBean (FormTag.java:484)
at org.apache.struts.taglib.html.FormTag.doStartTag(FormTag.java:457)
at org.apache.jsp.WEB_002dINF.pages.data.featureTypes.Editor_jsp._jspService(Editor_jsp.java:163)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java :324)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.doForward (MultipleDelegatingTilesRequestProcessor.java:346)
at org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:398)
at org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig (TilesRequestProcessor.java:318)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processForwardConfig(MultipleDelegatingTilesRequestProcessor.java:95)
at org.apache.struts.action.RequestProcessor.process (RequestProcessor.java:241)
at javax.servlet.http.HttpServlet.service (HttpServlet.java:709)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke (FilterSecurityInterceptor.java:107)
at com.vividsolutions.jts.io.WKBReader.read (WKBReader.java:137)
at com.vividsolutions.jts.io.WKBReader.read(WKBReader.java:118)
… 117 more
at org.geotools.data.jdbc.JDBC1DataStore.buildSchema (JDBC1DataStore.java:1166)
at org.geotools.data.jdbc.FeatureTypeHandler.getFeatureTypeInfo(FeatureTypeHandler.java :197)
at org.geotools.data.postgis.PostgisDataStore.getSchema (PostgisDataStore.java:1929)
at org.vfny.geoserver.form.data.TypesEditorForm.reset(TypesEditorForm.java:314)
at org.apache.struts.taglib.html.FormTag.initFormBean(FormTag.java:484)
at org.apache.struts.taglib.html.FormTag.doStartTag (FormTag.java:457)
at org.apache.jasper.runtime.PageContextImpl.include(PageContextImpl.java:602)
at org.apache.struts.tiles.TilesUtilImpl.doInclude (TilesUtilImpl.java:99)
at org.apache.struts.taglib.tiles.InsertTag.doInclude(InsertTag.java:760)
at org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEndTag (InsertTag.java:892)
at org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspx_meth_tiles_insert_7(mainLayout_jsp.java:1322)
at org.apache.jasper.servlet.JspServlet.service (JspServlet.java:236)
at org.apache.catalina.core.ApplicationDispatcher.processRequest (ApplicationDispatcher.java:474)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java :312)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.doForward(MultipleDelegatingTilesRequestProcessor.java:346)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processTilesDefinition (MultipleDelegatingTilesRequestProcessor.java:212)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processForwardConfig(MultipleDelegatingTilesRequestProcessor.java:81)
at org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor.java:318)
… 117 more
