[Geoserver-users] WFS 1.1 and GML3SFL0
Hi list,
what is the status of WFS 1.1 and GML3SFL0 in Geoserver? Is there a war file already to test with? If not, when can it be expected?
Thanks in advance.
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
bartvde@anonymised.com
http://www.osgis.nl
Hi Bart,
The OWS4 project is just starting to ramp down, we are close to cite conformance. As for having it part of geoserver core and being included in releases that is still a while off. As of now the target is 1.6. I would estimate at least a month before the first RC.
However, if you really want to check it out early there is a branch where the work is being done:
https://svn.codehaus.org/geoserver/branches/ows4
If you are interested I can help you build a war for it. But I should note what is there is a very stripped down version of geoserver. Essentially just a catalog and the wfs module, no ui or configuration subsystems.
-Justin
Bart van den Eijnden (OSGIS) wrote:
Hi list,
Thanks in advance.
Best regards,
Bart
