[Geoserver-users] WFS 2.0 bounding box not generating srsNAME
New to the mailing list, so if I am posting this wrong, please forgive my inexperience.
I have a geoserver endpoint serving INSPIRE compliant environmental data (EPSG:3035) as WFS 2.0 (GML 3.2) through AppSchema from a PostGIS (pg 9.4) database.
I see that there is an error in my geoserver instance:
For the wfs:boundedBy element there is no declaration of srsName, and while that bounding box is correct and valid, since the srsName isn’t specified, GML validators, like the one from opengeospatial, http://cite.opengeospatial.org/teamengine/viewSessions.jsp, will not validate my GML, saying that the bounding box for WFS doesn’t have a SRS associated.
This issue is with any WFS generated GML, none of the requests seem to generate the required attributes for the WFS’s Envelope (i tried with shapefile, direct postgis data connections etc).
Is this a known issue for geoserver, or is it just a configuration that I am missing??? I am striving to get a response similar to the one bellow:
wfs:boundedBy
<gml:Envelope srsDimension=“2” srsName=“urn:ogc:def:crs:EPSG::3035”>
gml:lowerCorner2687567.4042999963 5533251.203599997</gml:lowerCorner>
gml:upperCorner2781594.9288999955 5660608.522499993</gml:upperCorner>
</gml:Envelope>
</wfs:boundedBy>
wfs:member
<au:AdministrativeUnit gml:id=“BC”>
gml:boundedBy
</gml:Envelope>
</gml:boundedBy>
Kind regards,
Sorin RUSU
A quick code glance suggests that the bounds collected in the
WFSParsingUtils.FeatureCollectionType_getProperty do not contain the CRS
which prevents the encoder from encoding the info you require.
Why there is no CRS? It's probably bacause the specific FeatureCollection
implementation does not provide that info.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-2-0-bounding-box-not-generating-srsNAME-tp5277608p5277709.html
I’m not familiar with complex feature collections, but wondering if this might be a normal limitation,
or maybe if the feature type in question does not have a geometry as a top level attribute.
I’ve cc’ed Ben, he surely knows more than me on the subject
Why there is no CRS? It’s probably bacause the specific FeatureCollection
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports.http://sdm.link/zohodev2dev
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I don’t think this is an issue specific to complex feature collections, or at least I don’t believe it is.
The data are in a PostGIS 2.2 database (on PGSQL 9.4) with EPSG 3035 encoded.
I tried using several WFS services, directly from PGSQL and also from a shapefile, all of them with the correct EPSG code, and in neither case the upper-most bounding box (the one enveloping all the returned geometries) does’t have the srsName returned. I have however tested this mainly on the WFS 2.0
And to comply with GML 3.2 specifications all bounding boxes, for individual features as well as for the entire response, must have the srsName explicitly stated within the XML.
Sorin RUSU
Geograf
În Duminică, 24 Iulie 2016 12:53:48, Andrea Aime andrea.aime@anonymised.com a scris:
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-users@anonymised.com.sourceforge.net
The example feature type has a top level geometry property. srsName on these geometries appear to be set correctly.
Kind regards,
Ben.
On 24/07/16 21:53, Andrea Aime wrote:
I'm not familiar with complex feature collections, but wondering if this
level attribute.
I've cc'ed Ben, he surely knows more than me on the subject
traffic
are
planning
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
On Sun, Jul 24, 2016 at 9:51 PM, Ben Caradoc-Davies <ben@anonymised.com>
If you don't know either what might be the cause of this, I guess we'll
need a ticket at https://osgeo-org.atlassian.net/projects/GEOS/summary with:
   - Sample dataset to reproduce
   - Full mappings
Ing. Andrea Aime
@geowolf
Technical Lead
Ah,
I did not see this mail till now.
Double checked, indeed it seems the srsName is never encoded for envelopes of WFS 2.0 responses,
even if they are made of simple features.
E…g:
http://demo.geo-solutions.it/geoserver/tiger/ows?service=WFS&version=2.0.0&request=GetFeature&typeName=tiger:tiger_roads&count=1
vs:
http://demo.geo-solutions.it/geoserver/tiger/ows?service=WFS&version=1.1.0&request=GetFeature&typeName=tiger:tiger_roads&maxFeatures=1
So no, the issue was not known (possibly because many try to avoid computing/encoding the bounds, as it adds extra cost). Please report it at the bug tracker
(see my other mail).
On Sun, Jul 24, 2016 at 3:59 PM, Rusu Sorin <rususorinvick@anonymised.com> wrote:
Sorin RUSU
Geograf
În Duminică, 24 Iulie 2016 12:53:48, Andrea Aime <andrea.aime@anonymised.com> a scris:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I also notice that, for WFS 1.0.0, the top-level response bounds are encoded as:
<gml:boundedBy><gml:null>unknown</gml:null></gml:boundedBy>
unless WFS / Features / "Return bounding box with every feature" is checked.
For WFS 1.1.0 and WFS 2.0.0, the top-level response bounds are not encoded at all unless WFS / Features / "Return bounding box with every feature" is checked, in which case every feature gets a boundedBy, as well a top-level boundedBy for the response.
Tested with topp:states on master.
Kind regards,
Ben.
On 25/07/16 08:42, Andrea Aime wrote:
Ah,
E..g:
vs:
the bug tracker
I don't think this is an issue specific to complex feature collections, or
at least I don't believe it is.
encoded.
does't have the srsName returned. I have however tested this mainly on the
WFS 2.0
Sorin RUSU
*Geograf*
level attribute.
traffic
are
planning
Ing. Andrea Aime
@geowolf
Technical Lead
traffic
are
planning
Director
New Zealand
Hi Ben,
did you check the schemas? I have vague memories that what you’re reporting is the expected behavior,
as in WFS 1.0 there is no way to omit the element, but it can be reported explicitly as missing, while
in WFS 1.1 and 2.0 the element is optional.
On Sun, Jul 24, 2016 at 11:00 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
gml:boundedBygml:nullunknown</gml:null></gml:boundedBy>
unless WFS / Features / “Return bounding box with every feature” is checked.
For WFS 1.1.0 and WFS 2.0.0, the top-level response bounds are not encoded at all unless WFS / Features / “Return bounding box with every feature” is checked, in which case every feature gets a boundedBy, as well a top-level boundedBy for the response.
Kind regards,
Ben.
Ah,
E…g:
vs:
the bug tracker
encoded.
WFS 2.0
Sorin RUSU
Geograf
andrea.aime@anonymised.com1107…> a scris:
level attribute.
traffic
are
planning
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
traffic
are
planning
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Good thinking, Andrea. The schemas look quite different to WFS 1.1.0.
The WFS 2.0 schemas:
http://schemas.opengis.net/wfs/2.0/wfs.xsd
The wfs:boundedBy element is optional:
<xsd:element ref="wfs:boundedBy" minOccurs="0"/>
And the type is xsd:any:
<xsd:element name="boundedBy" type="wfs:EnvelopePropertyType"/><xsd:complexType name="EnvelopePropertyType">
<xsd:sequence>
<xsd:any namespace="##other"/>
</xsd:sequence>
</xsd:complexType>
The bindings create a GML 3.2 EnvelopePropertyType which has an srsName attribute, but I do not know if the encoder is smart enough to ask for it for an xsd:any type.
Kind regards,
Ben.
On 27/07/16 20:10, Andrea Aime wrote:
Hi Ben,
did you check the schemas? I have vague memories that what you're reporting
encoded as:
checked.
Kind regards,
Ben.
Ah,
E..g:
vs:
the bug tracker
encoded.
the
the
WFS 2.0
Sorin RUSU
*Geograf*
top
level attribute.
traffic
are
planning
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely
for
the attention and use of the named addressee(s) and may be confidential
or
Code).Any use not in accord with its purpose, any disclosure,
reproduction,
copying, distribution, or either dissemination, either whole or partial,
is
or
traffic
are
planning
Director
New Zealand
Director
New Zealand
