Can you repeat this behaviour for example with the "states" feature type? I could not. I tested with the OpenGEO demo server with unknown version and with my own v. 2.3.3 and I seem to get the expected result from both with the following request which I modified from yours.
-Jukka Rahkonen-
Christian Maul wrote:
Hello,
with the update from 2.1.3 to 2.3.3 the WFS behaviour has changed suddenly
The following request
http://sii-
wms1.nre.vic.gov.au:8180/geoserver/ows/wfs?request=GetFeature&version=1.
1.0&typeName=sii:SURVEY_MARKS_POINT&BBOX=145.296473,-
37.876557,145.301065,-
37.875032,EPSG:4326&outputFormat=json&propertyName=DISPLAY_NAME,MA
RK_ID,SYMBOL_TYPE_MGA,SHAPEwhich displays the attributes of one survey mark in 2.1.3 correctly, responds
now with quadrupling the information and displays in 2.3.3 the attributes to the
survey mark four times and does so consistently.
I've verified this behaviour with the old version. Is there anything I need to
change in the request? Checking the database there is one record for this mark
and only one point.I, then played around with the attributes I want to display
(propertyName=DISPLAY_NAME,MARK_ID,SYMBOL_TYPE_MGA,SHAPE) and for
two attributes I get the whole lot twice, for three attributes thrice, for four
attributes four time etc.Is that intended behaviour?
Slightly puzzled
Christian
____________________________Dr Christian Maul
Project ManagerInformation Services Branch
Department of Sustainability and Environment Level13, Marland House, 570
Bourke Street Melbourne 3000PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-
behaviour-changed-tp5070752.html
Sent from the GeoServer - User mailing list archive at Nabble.com.------------------------------------------------------------------------------
Get your SQL database under version control now!
Version control is standard for application code, but databases havent caught
up. So what steps can you take to put your SQL databases under version control?
Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
Geoserver-users mailing list
