On Tue, Dec 15, 2015 at 6:19 AM, RohitGarg DevLead <rohit.garg@anonymised.com>
wrote:
I was published one WFS service using geoserver (ver. 2.8.0) and I want to
use WFS service in QGIS for query purpose. But I don't want user can
download the data as shapefile.
Please help me where I have to change wfs getcapability service related to
workspace.
there is no way to disable output formats without a bit of programming,
they have to
be removed from the application context file, and then possibly find out
what else is breaking
because they are no more around (e.g., some WPS stuff might stop working,
there could
be other stuff too).
If you really want to go there, I can give you a small hint, you should
comment out this line:
https://github.com/geoserver/geoserver/blob/master/src/wfs/src/main/java/applicationContext.xml#L607
in the gs-wfs-<version>.jar found in the webapps/geoserver/WEB-INF/lib
directory.
Mind, if you really don't want people to dump out your data, the above
change is pointless,
they can just use ogr2ogr to go to the GML output and turn it into whatever
other format
they desire, the only way to actually disallow a dump is to disable WFS.
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
